Old Sat 23 February 2008, 12:19
. . . . the first grinder started emitting puffs of smoke (it was a cheap Ryobi I had on hand) so hauled out some cash, bought a Bosch grinder and modified my jig plates to accept this grinder. What a difference! more power, less vibration and almost lash free gear head. . . .
Old Thu 08 May 2008, 14:22
...and that extra 1.1amps makes a HUGE difference when grinding the profile. I burned up the 402 model in one rail....the 452 model is still going strong on my workbench.
Old Sun 11 May 2008, 19:20
dmoore
The Ryobi AG452 died in a hail of smoke. I may have been pushing it a bit hard but it was still a little under powered for the job. I replaced it with a Milwaukee 6148.
Old Tue 13 May 2008, 00:07
. . . . a brand new 850 watt Einhell grinder. At first I notice a lot more power than my old 500watt Bosch that I used on my Y-Rails. But after about 40 minutes...poof...smoke...no more grinder. Just shows, some things are tougher in life than others. The Bosch is about 10 years old, did a lot of hard work, but is still going.
Old Tue 11 November 2008, 23:26
kn6398
Just call me: Kray
Fort Worth
. . . . I burned the Chicago cheap grinder and had to buy higher amper grinder. . .
Old Sat 29 November 2008, 10:29
A little graveyard of grinders assembled above. Did I miss anyone?
Old Sat 29 November 2008, 10:40
Technically, I didn't burn out my cheap Chicago grinder on the rails, although it did die later during paint prep. When I went from the Chicago up to the Milwaukee 6148, my working rate on the rails went up by about 3X.
Old Sat 29 November 2008, 11:17
vishnu
Just call me: vishnu
Coimbatore(TN)
OOps i have burnt my cheap chinese grinder even before i started cutting. Planning to borrow and get my job done. For continious jobs say no to Chinese items poor quality. Hope how our friends in USA are dependant on China for everything. Let's not go there
Vishnu
Old Sat 29 November 2008, 11:54
YRD
Just call me: Yuri #17
Brasilia - DF
Brazil
I own a Chinese and an Makita.
I think the Chinese warms faster, so a smaller production process.
If you expect cool and respect the ability of equipment, no problem
Old Sat 29 November 2008, 12:11
This thread is to record the grinders burnt while building a MM. The thread is in the Rails & Rollers topic. The idea is for newbies to make wise choices when getting a grinder for doing the rails. It is NOT meant for a general discussion of the quality produced by a particular country.
Old Fri 21 January 2011, 19:39
Red_boards
Just call me: Red #91
My DeWalt was new when I started the build. After the rails its bearings are sounding really harsh (and it didn't fit exactly into the skate). I was careful to do a few passes and then let the grinder cool, and I think this saved its life. No magic blue smoke yet, but I feel it's on its last legs. Maybe a bearing change will renew it. There's a bit of grinding and cutting yet to be done (including the z-axis).
Old Sat 22 January 2011, 06:04
Red, I know all to well what you're refering to, look at my story
Old Sat 22 January 2011, 13:31
Red,
Went thru two grinders on mine....I was a little impatient on #5...took my time on the second two machines and have had no other burn outs.
Repack the grease in the grinder head. There are two little 90 degree crown gears in the bath of grease that seem to "blow up".....(it's not a pretty site).....and replace the brushes.
Old Sun 06 February 2011, 11:36
isladelobos
Just call me: Ros
Canary Islands
Spain
I have one old Dewalt DW819 and his Brushes has ben finish.
I live in one island and is sometimes hard to find parts.
In one car electrical garage i take old alternator brushes and refurbishe the grinder with this.
Now i can test with the long rails hard work.
This Dewalt fit perfect in the Scate.
Old Tue 17 May 2011, 12:53
tjskmm
Just call me: tjsk
CA
I have the laser-cut skate parts from the kit and do not want to modify them. Other than the need for longer screws, which grinder models fit the kit without modification to the skate part or the grinder?
Old Tue 17 May 2011, 23:00
The grinder mounting screw is almost always wrong, you will still need to modify the hole position now matter what.
Old Tue 17 May 2011, 23:17
tjskmm
Just call me: tjsk
CA
What make and model was the rail skate originally designed for? I have a couple of grinders that do not match the mounting holes/slots, and don't care to go out and buy more trying to find one that works. The laser cut parts from the kit do not leave too much room on the top holes to experiment with. The distance between the mounting plate and the grinding disk surface will vary from one manufacturer to another. I've read the original posts on the design process, and there is no definite answer there, either. SOMEBODY has to know.
Old Wed 18 May 2011, 01:49
http://www.mechmate.com/forums/showt...6&postcount=61
Later, the basic hole diameter was increased to suit more grinders. The forum didn't have a consensus on the definitive grinder.
Old Wed 18 May 2011, 05:58
The El cheapo version 4.5A min grinder from Harbor Freight fits, and most Ryobi's from Home depot. But you will have to get the longer metric hardware from the store with spacers to properly mate to the grinder to the skate to keep the disk coplanar.
