When running G-code (or jogging) the stepper will either move in the correct direction or in the opposite direction, randomly. I've replaced the Gecko drive and the wires to it (some looked pretty cooked). I even replaced the entire PC that I use to run the G-code; I made a clone as a spare, when I set up the machine.
Before and after all the attempts at repair, the malfunction happens exactly the same, without the slightest change. I don't know what to try next. |
Is it just on one axis?
If you swap either the motor, or driver with another one does it keep doing it on the same one, or on the swapped one? |
| HELP! Motors "lock" when going reverse/backwards (negative)! | Jannes20 | Archives | 2 | Tue 28 April 2015 21:53 |
| Starting out to actually cut something - cutters, speeds, depths, directions, etc. | Richards | General - MM Operating | 22 | Tue 09 July 2013 04:02 |
| Inspired to go forward - Maine | framerman | Introduce yourself and start planning | 11 | Sun 13 January 2013 07:28 |
| Moves at different speeds for different directions - feed rates incorrectly defined | Kobus_Joubert | Troubleshooting | 16 | Sun 22 March 2009 06:16 |
| Random pictures at the top of each page. | liaoh75 | Archives | 2 | Fri 22 August 2008 09:06 |
