Speeds.
Evening All,
I'm really interested to hear what feeds and speeds people are using to get an understanding of what's happening with my machine, and to see if I can improve on what I've currently got. I've been machining some 15mm ply, and slowly ramped up my speeds, suddenly my whole sheet had 'ghosted' Tried re-homing and running an air cut,.ended up binning 3 sheets of material and stripping down a gear box and checking grub screws were tight and replacing a stepper motor. Lost a day of machine time, and well felt somewhat defeated. Currently running a 2.2kw water cooled spindle, had a 6mm twin flute low helical cutter, running multiple passes at about 15kish rpm , I've been higher and lower and seem to be able to get about 3500 to 4000 mm per minute, using uccnc. Many Thanks |
| Starting out to actually cut something - cutters, speeds, depths, directions, etc. | Richards | General - MM Operating | 22 | Tue 09 July 2013 04:02 |
| Speeds, Feeds, Materials and Bits | smreish | Cutting various materials - bit selection, feeds, speeds | 65 | Sun 11 March 2012 09:01 |
| Feeds and Speeds #84 - Mortara, Italy | vanja.ivancic | MechMates already cutting | 36 | Mon 04 July 2011 05:53 |
| Cannot get good jog speeds - first thought PS voltage too low, then current error | kwang90020 | Troubleshooting | 11 | Tue 17 March 2009 14:28 |
| Convert dimensions, speeds, forces, temp, etc from metric to inches etc. | Kobus_Joubert | Utility software | 2 | Tue 19 August 2008 18:10 |
