Old Tue 09 August 2011, 07:32
boblee
Just call me: Bob
Fort Fairfield Me.
purpose of z axis gas spring
Hi Everyone
I've visited this site from time to time and drooled over the mechmate design .
I'm thinking of building and have a question concerning the z-axis gas spring .
what is it's function or purpose ?
Bob
Old Tue 09 August 2011, 08:41
It acts as the counter weight for the z axis. If it is not there the full weight of the parts would be felt against the motor. Think of a draw bridge balance.
Old Tue 09 August 2011, 13:41
boblee
Just call me: Bob
Fort Fairfield Me.
Makes sense
Does it affect backlash in any way?
Old Tue 09 August 2011, 16:48
No it does not.
Old Mon 03 October 2011, 07:23
Bob,
the side effect of having such a gas spring is that your hight will be set more accurately and your Z axis will move more smooth.
The reason for this is that a stepper motor uses micro stepping and if a stepper motor is in a micro step, then it will loose strength as well. When the full weight is on the stepper motor, the stepper motor will go back (give or take) in a full step position because it doesn't have enough torque to hold it into a micro step.
You will see that if you have no gas-spring and you move your Z up and down, you will only get full-step accuracy. Top of my head, that was 1/3 of a mm in my case.
Old Thu 06 October 2011, 10:07
buuk
Just call me: Buuk
Hi,
I have one more question about the gas spring. Is the gas spring extended in its normal (free/rest) state? As this would mean that when moving the Z gantry up, you would have to lift both the weigth of the slide, router, etc. + the pressure of the spring...
Thanks in advance,
Luc
Old Thu 06 October 2011, 10:47
Luc,
the normal position of the gas-spring would be extended so it pushes against gravity.
So it counter balances the wight of your spindle and your Z axis so your Z stepper doesn't have to work so hard.
Also, when you buy your gas-spring, make sure it doesn't counter banker perfectly, but always have so push again or for gravity so your rack+pinion always make good contact
Old Thu 06 October 2011, 10:51
When the z-slide is up then the spring is extended....when the z-slide is down then the spring is compressed.
The bottom of the gas spring is fixed to the y-car, the top of the gas spring is fixed to the z-slide.
Old Thu 06 October 2011, 11:22
buuk
Just call me: Buuk
Thanks for your quick replies.
I was thinking correctly about the forces, but made a mistake in which part was moving... stupid of me. But such things happen after a long day at work. Excuse me for this question...
Thanks anyway!
Luc
Setting A-axis terminal as X2-axis in EMC2 KenC CNC motion control software 2 Wed 27 January 2010 05:40
Rotary axis (4th Axis) or Indexer software smreish Graphics & CAD 0 Tue 28 July 2009 06:02
FreeCAD - will be an open source general purpose 3D CAD modeler isladelobos Graphics & CAD 0 Sat 07 February 2009 04:25
Gas Spring : Compatible automotive gas spring Nikonauts 40. Z-Slide 0 Sat 03 January 2009 09:59
Umbilical Plate Purpose/Role fabrica 10. Base Table 7 Tue 20 February 2007 12:20
