Old Sat 07 June 2008, 04:10
Progress on my Lathe project #23 - Plettenberg Bay, S.Africa
Hi ALL
I have started building my MM as I got jealous looking at the progress of other builds in progress and as someone once told me , start pulling finger and start building so let the adventure begins.
Gerald thanks once again for the plans.I started last night with welding the y-car together and it all just clipped together ,made life easy.I will try to post a photo later during the day.
Old Sat 07 June 2008, 04:39
IN-WondeR
Just call me: Kim
Randers
Denmark
Welcome to the forum hennie....
We are looking forward to seeing lot's of pictures as your build progresses...
Old Sat 07 June 2008, 05:10
Go for it Hennie!
Old Sat 07 June 2008, 06:41
First Pic`s
Figured out how to resize so here are the first ones of the y-car welded and an attempt at fitting the base of my reduction gearbox to the motor plate.
I must still drill the four holes to attach the plate and do some work on it.
Old Sat 07 June 2008, 11:22
dmoore
A great tool for this is (if you use windows) is the Microsoft Power Toys Image Resizer:
http://www.microsoft.com/windowsxp/d...powertoys.mspx
Just right click the photo and then select resize to 640x480.
Old Sun 08 June 2008, 03:40
Mounted gearbox base
This is my first attempt at fitting my reduction gearbox base plate onto the motor mounting plate.Still need to do some work on it but the idea is there.
Old Sun 08 June 2008, 06:12
Hoekom lyk daai kinders so stout?
Old Sun 08 June 2008, 08:04
By hulle pa geleer aanjaag.
Old Sun 08 June 2008, 08:17
Ja.well.no.fine
Old Mon 09 June 2008, 00:42
Hi Hennie,
Glad you got started..at least I am still a little ahead. Good luck.
Old Mon 09 June 2008, 02:07
Goed gedaan Hennie, and what do you mean Kobus that you are little ahead, you are almost finished
Old Mon 09 June 2008, 05:13
Its a thing between us.
Had all my electrical parts ordered by a local shop and got a good deal even on the cables ( lapp ).
Old Mon 09 June 2008, 05:18
Did you get the Lapp cables from the guys in Cape Town or were you able to source them locally? what sort of prices did you pay?
Old Mon 09 June 2008, 05:52
From the guys in Cape Town through the electrical supply shop.Apparently they moved . Phone them they might have some off cuts that they want to get rid of!
Old Tue 10 June 2008, 05:48
Hi ALL
GERALD, I have not cut the main beams for my machine.The question that I need to ask is at what length do one need to start supporting the beams in the centre as although we cut a lot of 2750x1830 sheets on the table saw and that won`t be a problem for th MM one need that did pop up for my workshop is that we make a lot of solid wooden tops and while I am at an early stage of my built I might just as well
order an extra beam and make the length of the table to accommodate a 3500 mm top, width on the other hand would not be a problem.
Please help?
Old Tue 10 June 2008, 06:03
At about 3.6m [12ft], I would add more legs, or increase the strength of the beams.
Old Tue 10 June 2008, 07:02
The table should in total length be +/- 4 meters long and if legs be added they must be where the vertical bearers are?That is my thought.
Old Tue 10 June 2008, 07:24
That would be a nice logical place - ie add 4 small legs.
Old Fri 13 June 2008, 01:00
Gears
Gerald as you can see I have a small 15 t t5 timing pulley and a 60 t t5 .
as shown there is not much meat left once 14 mm has been drilled.
Old Sat 14 June 2008, 02:55
Hi Alan,
Got my cables and electrical box with all the switches ,relays. Lapp cables for the build as per what Gerald used on his machine was R 419.00 excl. vat.I don`t know if that is reasonable.
Old Sun 15 June 2008, 11:25
Belli
Just call me: Greg
Johannesburg
15t Pulleys
H Hennie,
I have used the 15t successfully many times on 1/2" shafts, you might consider going to a 17/18t pulley perhaps. Drill for two M3 grub screws in the root of a tooth and you will be fine. A drop of the low strength loctite will stop them from coming loose.
Cheers,
Greg
Old Sun 15 June 2008, 12:13
Hi Greg,
Will do that.Can you please mail me your wiring diagram again I have deleted the one you sent me.I have started putting my control box together.I would like to know on the bob which contact points I need to use for my proxy switches and which I can use for my router or anyone that can help.
Kobus how are you doing on your box as you are further then me?
Old Mon 16 June 2008, 13:49
That seems very cheap, my estimate comes in at R2500.00 - 60m x 4core x 0.5mm, 15m x 4core x 1.0mm, 18m x 4core x 1.5mm, 18m x 7core x 0.5mm, 18m x 2core x 0.5mm. All Lapp Clasic shielded cable 115CY.
How do your cable specs compare to my list?
Old Tue 17 June 2008, 00:25
Alan when did you get your quote? I did notice that I do short 4 core x .5mm about 30 meters.I am also increasing the length of my table so I will have to order some more.I am gong to attach the box to my table so I don`t need to run cable from lets say if the box was mounted on the wall.
Old Tue 17 June 2008, 00:34
Hi Hennie, update on my build will be in my thread later. That price for box, cables, switches sound very cheap...exactly what did you get...give us a list.
Old Tue 17 June 2008, 00:55
Hi Kobus
Total price incl. cable (box, switches, the works)R 2218.60
( will post pic`s on what I got and what I did this past weekend)
Old Wed 18 June 2008, 23:53
After our telephone conversation.
On the Mach3 BOB the following: The numbers on the PC board is basically the PORT number. If you look at the drawing of Greg, the last 4 blocks on the top right hand is where I connected my 4 Gecko's.
If you use G202's then the +5V of the BOB connects to the Gecko COM.
The first Gecko DIR-ection will connect to Pin 2 of the BOB
The first Gecko Step will connect to Pin 3 of the BOB.
In MACH 3 you go and configure the ports accordingly
The same for the other 3. You connect the wires to the pin number on the BOB, and go and configure that number on MACH3....easy
Old Thu 19 June 2008, 00:13
MOE..E DANKIE!
Ek het dit so gedoen.
Old Fri 20 June 2008, 00:04
Gerald
Would it be a problem if I use 20x20 mm sq bar for my x/y stopper blocks?
(have 12 meters lying in my way).
I have decided on the length of the table.I would first cut a piece of 2250 mm for a cross bearer out of the 180x70 channel .This will then become the first one on the end of the table and so also for the last one this still gives me a table of 3750 mm.This would be more sturdy on the side that one load the material as some boards are quite heavy and not easy to handle.I usually see the oaks in my w/shop battle when they cut a big board or top on the table saw.( would love to do 4 meters but space becomes an issue.)
Old Fri 20 June 2008, 00:36
You may have to chamfer the top of the stopper block to miss:
- The V-wheels (x+y axis)and their bolts as they pass
- The underside of the y-car's 2mm plate skirt
.......but I doubt it.
Another Mechmate in Progress - Atlanta GA Jay Waters Construction started, but not cutting yet 33 Fri 22 April 2011 08:35
cnc wood lathe javeria Miscellaneous / General / Whatever / Catchall 5 Fri 11 March 2011 09:12
Starting to make progress peter__jackson Construction started, but not cutting yet 7 Wed 27 October 2010 11:28
Lathe cabinet lumberjack_jeff The Show Room 2 Sun 26 September 2010 21:41
Website/ Forum for homemade/conversion cnc lathe? jgc2521 Miscellaneous / General / Whatever / Catchall 1 Sun 28 February 2010 01:31
