Hi new member
Hi I'm Rob.
I own a one man opperation guitar company in Adelaide, Australia. I'm looking at building a small machine to cut the body's out, around 3' x 4' x 2 1/2" cutting size hoping this machine can be down sized to fit the bill. I currently use a copying machine I made to make the bodys but as I need a body blank and the master side by side it takes up half my garrage not to mention that it is labour intensive. Any advise would be greatly appreciated. Rob |
I think I would go 4x4 at the smallest. That way you could cut half sheet ply.
Thanks, I should have mentioned that I mostly use solid timber and the structural ply I get comes in at 2 1\2" widths. I will concider the extra width though it could be handy for home improvement projects.
Rob
Some people are using a machine to cut their necks also. |
I was going to try making necks and neck through body's once I had everything all worked out.
| jack new member | jackrogers | Introduce yourself and start planning | 3 | Fri 15 March 2013 21:32 |
| New Member, Need Help | Lord Maximus | Introduce yourself and start planning | 3 | Fri 01 February 2013 07:57 |
| I'm a new member to this forum | Mr Ron | Introduce yourself and start planning | 2 | Fri 22 June 2012 19:29 |
| New Member has Questions | hevertg | Introduce yourself and start planning | 22 | Sat 09 June 2012 17:43 |
| New Member - Hudson, MI | cpdenco | Introduce yourself and start planning | 12 | Fri 17 February 2012 09:41 |
