Cutting wrong measurement
Ok,
So my mech mate is running very well. The only issue so far is that the cut is short ever so slightly. Tops 1/16 over 48 in (calipers show near perfection) I've ran the steps per calculation, Still off ever so slightly.... The bit also does not end smooth every time (primarily on rectangles) It produces a small lump at the start point. Way worse if I run lead ins. I'm extremely frustrated, And ideas would help, Jason |
Specs on your machine? Motors? Router? Size of your table?
Pictures, Logos? ![]() |
What software did you use to create the Gcode? What size bit are you using? What software are you using to run the MM? More details are needed.
If you have marks on start point and its larger with leading then you have some mechanical slop in system, check pinions or belt drives, check v-wheels
and of-course show us your MechMate |
My fixes were:
Check bit (Z-axis) is vertical to table Tighten Z rollers |
| VFD wiring - right or wrong | javeria | 60. Wiring & Cable Management | 12 | Tue 27 July 2010 21:41 |
| Coil Inductance measurement, is this normal? | KenC | Motors & their mountings | 8 | Thu 19 November 2009 02:36 |
| One motor goes wrong way - How to reverse its direction | grandpi | Troubleshooting | 2 | Sun 17 February 2008 23:03 |
| Machine runs far too slow (or fast) and the wrong distances - Confusing inch/mm 's | Hugo Carradini | Troubleshooting | 2 | Tue 25 September 2007 10:44 |
| Failure Mode and Effects Analysis - What if something goes wrong | Gerald_D | Archives | 0 | Wed 07 March 2007 23:44 |
