nema 34
my friends,
After once again overcome personal problems continue with the planning and construction of CNC, Ah, life is sometimes very difficult, but always after the rain comes the sun, and opposite I think that this is a stepper motor ![]() Uploaded with ImageShack.us is very similar :::: PK296A2A-SG7.2? greeting |
There are three important data items that should be part of motor selection.
1. Physical size = 34 2. Holding torque = [at least] 350 oz*in (2.5 newton metres) for geared or belted motors, [at least] 600 oz*in (4.25 newton metres) for motors without reduction 3. Induction (mH). Lower is better. The motor you selected has high inductance. It will work with an 80 VDC power supply, but a motor with 1.5 mH to 2.5mH would be my choice. |
Wiring for NEMA34 640 OZ-IN 4.5A STEPPER MOTOR (KL34H280-45-4A) 640 oz In. Hy
When wiring the 4 motors that I ordered from metal head mike. Do I connect the wires for the coils at the motor? And just put a wire nuts on them. What are the methods for connecting the motors to the system. I have concerns about the vibration that will occur during operation. Help!!
NO WIRE NUTS.
Use a connector like 4 pin XLR available at http://www.markertek.com/Connectors-...nc/NC4FX.xhtml Or - other locking 4 pole connector rated for 10Amps @ 80VDC Or - butt joint, solder and heat shrink the connection and home run to control box drivers. |
Or better yet, Western Union joint, then solder and heat shrink!
![]() http://www.tpub.com/neets/book4/12a.htm Last edited by domino11; Tue 28 August 2012 at 15:51.. |
Heath....that's kinda what I meant! Thanks for clarifying
XLR Motor Connectors for KL34H280-45-8A
I do like the idea of the XLR connectors. Does anyone have a close up shot? I see the motors have 8 wires and I will be usings the 4 pin XLR connectors. Which wire goes where? Will I need to wire this bi-polar(Series or Parallel) or uni-polar? I searched Google and found http://www.kelinginc.net/KL34H280-45-8A.pdf
This is the fun part with DIY, you get to decide which pin/wire goes where.
PS, I've never once need to disconnect the motor since mine was commissioned. IMHO, XLR connector is luxury. Last edited by KenC; Wed 29 August 2012 at 02:58.. |
bi-polar or unipolar
ok what about the unipolar vs bipolar?
#10
Read the sticky
| Nema 42 Motor Size Question | 15mgtar | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 10 | Fri 09 April 2010 03:39 |
| does anyone offer a kit with 7:1 reduction with nema 34 motors . . . . . | toad | Motors & their mountings | 25 | Thu 28 January 2010 01:08 |
| Do the Oriental Motor gearheads fit onto all NEMA stepper motors? | alain26 | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 7 | Wed 02 July 2008 09:57 |
