raw Particle board cutting
I need to cut a lot of 19mm Particle board, its raw, without melamine top.
Really its just packaging grade of board. Order is to cut about 20-30 sheets/month. There is around 35 pieces on one board so its a lot of cut path. Anyone has in mind some router bit to use? Edge quality is of no concern as it will be covered with fabric later. I need something rough that will just rip it apart ![]() had this in mind: http://www.cmtutensili.com/show_items.asp?pars=RC~196~2 around 35eur for 8mm , think that it will be strong enough to cut it in one pass. |
You may try with compression bit.
Compression bits are working for me when I have to cut sheet material.
digger:
samo ti zezaj I said its a low grade particle board with lot of impurities, and edge does not have to be perfect or good. So that is why I have not considered compression bit (price difference). |
| What to use to cut Melamine Board? | Daya | Cutting various materials - bit selection, feeds, speeds | 17 | Tue 13 March 2012 23:08 |
| Control Board Help Please | paul60 | 70. Control Systems | 8 | Wed 07 October 2009 23:52 |
| What is the purpose of a spoil board or bleeder board? | j_wizard | 10. Base Table | 1 | Sun 09 August 2009 18:00 |
| Cutting Foam Core Board | jhiggins7 | Cutting various materials - bit selection, feeds, speeds | 3 | Fri 17 April 2009 14:26 |
| cnc4pc board help | smreish | 70. Control Systems | 1 | Wed 23 April 2008 06:22 |
