Old Mon 17 November 2014, 05:37
Duds
Just call me: Dale
Canberra
Photos of cabling management requested
Has anyone got some photos of how you managed the cabling from the cable chain to the end of the Y gantry? The drawings show the box duct but did any of you use saddles or rack or tube? Pleas post photos of your cable management at this spot.
Also, how did you run your umbilical? Did you bundle it in some corrugated flex or core drill through the floor and onto rack then back up to your board. Did you drop it from the ceiling on tied to a pole. If you ran on the floor did you use mechanical protection for you umbilical cables, pipe, ramps, false floor? post photos of how you avoid trip hazards and your umbilical.
Dale
Old Mon 17 November 2014, 10:20
Dale,
I have used two solutions.
The first, I came out of the x cable chain and turned down to the floor.
Once on the floor, I built a plywood cable ramp about 12" wide to keep signal and power separated until it got to the wall with the control box mounted above.
Second machine, just bundled all the cable into a nice festoon and swag to the wall which was about 24" away on the "non person" side of the machine.
I'll look for pictures later on the home PC.
Old Mon 17 November 2014, 13:48
Duds
Just call me: Dale
Canberra
Thanks Sean
Old Wed 19 November 2014, 22:19
I used PVC pipe to the end of the machine and my enclosure is located not far from the end of the machine.
Old Thu 20 November 2014, 05:30
Dale, along the way, someone did part or combination of all the methods you mentioned and more... Some how, everyone has their own concoction on wiring...
Old Thu 20 November 2014, 15:56
DocTanner
Just call me: Don Ross
Blue Ridge, Texas
I used Non-Metallic Liquid Tight conduit and connectors. Electrical supply houses sell various sizes. It lays on the floor. After several years it remains undamaged.
DonRoss
Old Fri 21 November 2014, 11:48
normand blais
Just call me: Normand
montreal
Here are some pictures
http://www.mechmate.com/forums/showthread.php?t=890
Old Fri 21 November 2014, 14:58
Duds
Just call me: Dale
Canberra
Thanks Don, Normand Ken and Pete.
Old Fri 21 November 2014, 15:34
I used 1" EMT tubes & ends.....economical & easy to find for me !!
See here : http://www.mechmate.com/forums/showt...&postcount=122
And
Old Mon 07 February 2022, 22:24
AlexTup
Just call me: Oluluron
AlexTupCN
Russia
Send a message via ICQ to AlexTup Send a message via AIM to AlexTup Send a message via Yahoo to AlexTup Send a message via Skype™ to AlexTup
Does anyone know of a good way to get my mac pro 30 away in another room?
The firewire and USB I can figure out, but has anyone found a good dual monitor dvi cable? Or wireless?
Shaun
Old Wed 09 February 2022, 11:11
Check at www.monoprice.com. They have lots of cables.
Photos Needed MetalHead Miscellaneous / General / Whatever / Catchall 13 Thu 19 January 2012 11:47
Cabling Management with Cable Trays LyndonDevazier The Market Place 0 Tue 17 January 2012 22:22
Attaching photos to posts on this forum Gerald D About this Forum 27 Sun 14 February 2010 13:41
Dust Management System dmoore Archives 8 Fri 20 June 2008 20:53
