about to start buying to make my table
hi, maybe this question have been aroung since ages but can't find any answer to my pledge.
i am about to build my mech but there is a lot of different information and options. my table will be 8 x 10 feet. recently i've seen interesting design based on aluminum extrude, is that suitable for routing? is it stable and sturdy enough? my idea is to have a dual purpose table: plasma and router changing the head of the spindle to make the movement lighter. what i would like is a general avice on what direction should i follow. next i'll list what i have considered to build my model, please help me deciding because i know a wrong direction to follow means a lot of money at the size i am planning: for general structure aluminum extrude as linear rail i plan to use round sbr20 pinion and gear nema34 for all axes ballscrew for z axis. i am actually looking for information before doing anything else. i konw this information is kind of vage but would like ti know opinions to start defining details of my project thanks a lot |
Multi-purpose machines are generally compromised, they always end up being the Jack of all trade, Ace of non...
so your recomendation is going for two setups. any suggestions about the list i wrote? actually what i need to cut with plasma is pretty simple shape so the specs should point to router. is aluminum possible?
Aluminum is possible, but it's not what we do here, we are pretty dedicated to the MechMate design, which is welded steel. There are many other possible designs; see cnczone for them.
In general, the aluminum designs are not as stiff, which matters when taking either large or accurate cuts in wood; for plasma they are sufficient. Your list of materials implies on of the aluminum designs; the MechMate design relies on fabricating V-roller rails from steel. You may want to research a bit more on what type of machine best fits your needs, and if you choose the MechMate design you'll find lots of support here. |
thanks a lot bradm, i am investigating the best option to build.
i think i'll go aluminum for plasma and mechmate for router, i'll take your advice. thanks a lot |
| Planning to Start In PA | technoid | Introduce yourself and start planning | 1 | Fri 22 April 2011 06:25 |
| searching for buying a mechmate | ebarotte | The Market Place | 3 | Sun 30 January 2011 05:57 |
| Dealing with taxes when buying overseas | riesvantwisk | Miscellaneous / General / Whatever / Catchall | 11 | Tue 20 January 2009 20:47 |
| Where to start, no really! | ChiknNutz | General - MM Build | 6 | Mon 15 December 2008 21:06 |
| Buying rack & pinions in South Africa | JanJC | Archives | 1 | Tue 16 October 2007 23:41 |
