My 4th axis
Hello guys,
Here is my design for the 4th axis. It's not complete but this week I hope that will be ready. I hope it will help somehow. Marius |
A stand alone indexer ?.... You don't need Y-movement for something like this do you?
Y movement is very useful - think about using the cutter off center so you are cutting with the bottom of the cutter and not the side (wide flat bottom cutter) or if you want to do flutes with a side cutting bit that follows a curved profile down the length of the job - having all four axes work together opens up interesting posibilities.
BTW Marius interesting machine. |
Maybe Alan, but with Aspire I can do wonderful things on only 3 axis. I think programming will be more intense when you want to make use of all 4 axis.
But I agree with Alan, very interesting machine...and the fact that it leaves your Mechmate free to do other work is a BIG plus...nice going Marius. |
Hi Kobus,
My ideea was to remove the indexer if you don't need in order to use the router normaly. When I'll use the indexer there will be another profile in Mach. Something like that will be instaled on MM. Perhaps this week I'll finish the indexer to give a try with DeskProto. I was out of the country that's why I didn't send the g code. You can use the program for free in full 30 days. The price is more than OK. One more thing: DP is a true 4 axis program. So the all axis will work (I hope )A nice day to all. |
I did try your g-code that you send me and it looks OK. Only did a AIR-CUT.
I don't change my Mach profile as I have 5 drivers in my control box and all are wired to their steppers. When I do indexing, all I do is use the PostProcessor in Aspire for wrapping and away I go. When I cut x,y,z, I save my file with the normal Mach P-P and away I go. |
Aaaah!! now I can see them. Thanks a lot man, this is a great job.
| Setting the Y-axis square to the X-axis | Gerald_D | 20. Gantry | 10 | Fri 12 October 2012 01:44 |
| Setting A-axis terminal as X2-axis in EMC2 | KenC | CNC motion control software | 2 | Wed 27 January 2010 06:40 |
| Rotary axis (4th Axis) or Indexer software | smreish | Graphics & CAD | 0 | Tue 28 July 2009 07:02 |
| Longer Z Axis or 5 Axis | Hovernut | Archives | 31 | Sat 25 October 2008 16:56 |
