Auto Center Finder....
I know that someone has done this... but I cannot find it....
I want to automatically find the center of a hole. What I envision is a touch probe (already have z-plate zero working) that is a cup with a pin to index into a given hole. Put a rod/pin in the tool head (known diameter), jog over and down into the cup. Move the tool head (x and y) and find the center.... A link to someone else is better than redoing all the work of keying it in. Stan PS.... I just found one on Mach3 Forum... Thanks for looking and considering the issue Last edited by salewis; Tue 22 February 2011 at 09:51.. Reason: found what I was looking for..... |
Thanks! ![]() |
http://www.machsupport.com/forum/ind...c,15992.0.html
While it doesn't say exactly what I'm trying to do, it is the same concept. The third post down contains the code.. Stan |
Yep that's the idea except I am going to turn a piece and place a piece of 1/4 drill rod in the hole and stick it into a corresponding hole on the fixture. Think of flower stem sticking into a vase.
Stan |
| Corner finder | Rad Racer | General - MM Operating | 2 | Tue 28 May 2013 11:19 |
| Auto Tool Changer | WTI | 50. Toolheads | 38 | Mon 14 December 2009 13:30 |
| Auto Toroid Winder | WTI | 702. Power Supplies | 0 | Sat 20 June 2009 20:03 |
| Corner finder and cam clamps | Rad Racer | The Show Room | 9 | Sun 19 April 2009 10:06 |
| Starting my 1st build - Berlin Center Ohio | Bob Cole | Construction started, but not cutting yet | 3 | Sat 25 November 2006 08:41 |
