Old Sun 02 January 2011, 05:34
forumcnc
Just call me: 347 6527217
italia
Italy
Motore Stepper directly on the rack
Hello
Can you tell meif it is you can mount a motor directly on the rack without any type of gearbox and stepper motor to take power
Old Sun 02 January 2011, 06:29
You can direct drive the system without a gear box. NEMA 34 Motors are what the system uses.
http://www.solarbotics.net/library/p...f/motorbas.pdf
Welcome to the team also !!!
Old Sun 02 January 2011, 09:54
forumcnc
italia
Italy
thanks for the reply
But is there any online store where I buy them
Old Mon 03 January 2011, 07:44
forumcnc
italia
Italy
sorry I'm Italian and I could not find anything and indicates some possible
Old Mon 03 January 2011, 07:49
(I removed my previous post since I posted it logged in as Admin)
If you look at the main forum you will see it broken down in sections.
http://www.mechmate.com/forums/forumdisplay.php?f=26
Is where I would start. It talks a lot about the different motors. Also look at the "MechMates Already Cutting" and you will see completed builds and can learn from those threads also.
UIROBOT Stepper Drives uirobot The Market Place 76 Tue 31 January 2012 10:45
Rack Metric Size 1.5 liaoh75 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 26 Sun 27 February 2011 04:39
Mounting the rack blakekoehn Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 16 Tue 18 May 2010 01:26
Belt or Rack gustavoosorio Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Tue 16 February 2010 20:55
Rack alternate Art Archives 5 Fri 12 September 2008 13:04
