Laser Parts cutting with cnc router
Hi
Dear Gerald_D i am member since a year but was only learning, now i plan to get started, i am a Pakistani working in Abu Dhabi U A E, i will start to build in Pakistan, as import is a difficult process in Pakistan, importing in U A E is easier due to free port facilities, Laser cutting is available here in U A E but i have tried cutting with cnc router that our company import from china, i am gathering the parts at this time soon will start to build Regards |
Hi
here is the metal cutting video http://www.metacafe.com/w/5575371 http://www.metacafe.com/watch/557537...th_cnc_router/ |
Is that 1/4 or 6mm steel? How fast is that router turning?
according to the video comment, "3mm old steel with 4mm carbide bit"
seems to produce a slurry (for lack of a better word) rather than chips i'm curious also about the feed rate and type of bit (straight, spiral etc) |
Hi
Robin, The steel is 3mm tool is 4mm carbide G-code made in art-cam steel tool Feed rate 60 to 180 mm/min depends on type of tool, plunge rate 50 mm/min V F D controlled speed should be adjusted to an normal hand drill tool |
| MechMate Laser Kit Parts in the US | ddoggett | The Market Place | 62 | Wed 24 August 2016 11:12 |
| Laser Cutting Parts | lisawaa | The Market Place | 6 | Tue 14 September 2010 13:07 |
| Surplus Laser Parts | rotorzoomer | The Market Place | 0 | Fri 25 June 2010 08:32 |
| Laser cut and formed parts | Castone | Profiled (laser cut) & bent steel plate | 5 | Sat 05 September 2009 01:40 |
| Source for laser cut parts | Medemt | General - MM Build | 1 | Sun 29 March 2009 19:08 |
