Mach 3 CV settings
I'm cutting some 3D models using Cut3D and need to speed my cut times up (or is it decrease my cut times,
). I came upon this 3 page document on the Mach forum describing CV settings. Its a good read.http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf |
Greg,
I have read that page a bunch of times when I was having problems with my cutting. Yes, it is a very good thing. I have a little experience with this. Send an email or call if you still have my number. |
Thanks Bud,
The issue was me again. I had set my "look ahead" to 5 lines when I was cutting allot of profiles. Don't ask why, I now know there are better way for what I was trying to do. Anyways, now I'm cutting 3D models again and the cut quality was great, but I didn't like the "jerky" motion and long cut times. Changed the "look ahead" to 50 lines and everything is smooth, and fast. Reduced my cut times by one hour. ![]() The MM would be one heck of a machine if it wasn't for the operator. ![]() |
| Typical settings for Mach motor tuning | Kobus_Joubert | CNC motion control software | 19 | Sun 15 May 2016 11:04 |
| limit-settings/pin's and port's | kongblom | 70. Control Systems | 6 | Fri 20 November 2009 10:39 |
| Upgraded Mach, now the motors won't turn - Different ports/pins for later Mach | Hugo Carradini | Troubleshooting | 19 | Thu 25 October 2007 12:45 |
| Today's changes to the Forum settings.... | Gerald D | Test Area for this forum | 8 | Sat 26 May 2007 12:48 |
