Gmax-CNCtoolkit script & EMC2
Im planing to use this combination and was wondering if anyone else is using this combination, and if so how is it working out for you?
I haven't used gmax, but emc2 works well.
Thanks Jeff,
How easy to set up is it and are you running a VFD and spindle of it? |
No, I use a router. By all accounts it's more difficult to set up than Mach, but it's very flexible.
I had zero previous experience with motion control before installing this, but I use it in its most rudimentary way. Lots of people are using EMC2 for spindle control, z-plates and touch probing, but it's not plug and play. Gmax suggests that you intend to use a 4th axis? Last edited by lumberjack_jeff; Sun 15 May 2011 at 09:56.. |
Gmax from what I can gather will handle extra axis which i eventually want to do but another good thing for me is it runs off the 3d max interface and it's also free.
Thanks for the advice on e=mc2 as you say it's not plug and play but the ability to use it for different applications is an atraction for me. I like these open source programs as they are a bit like the mechmate experience. |
New videos of cnc toolkit posted here
| EMC2 - LinuxCNC (open source "free") | Gerald_D | CNC motion control software | 27 | Fri 24 December 2021 21:54 |
| Setting up EMC2 | servant74 | CNC motion control software | 62 | Wed 08 November 2017 23:03 |
| G540 running under EMC2 and Linux #10 - Somerville MA USA | bradm | MechMates already cutting | 68 | Thu 11 March 2010 09:13 |
| Setting A-axis terminal as X2-axis in EMC2 | KenC | CNC motion control software | 2 | Wed 27 January 2010 06:40 |
| Homing Sequence In MACH3 and EMC2 | kkilst | CNC motion control software | 3 | Mon 25 May 2009 11:02 |
