-   70. Control Systems (http://www.mechmate.com/forums/forumdisplay.php?f=28)
-   -   Basic schematic of a typical CNC control box (http://www.mechmate.com/forums/showthread.php?t=278)
Gerald_D Mon 12 June 2006 08:09
javeria Tue 05 May 2009 11:54
Some videos from Youtube explaining the control box similar to mechmate box
http://www.youtube.com/watch?v=hfpNodHRSgY
http://www.youtube.com/watch?v=gTvh_ifVqEQ
http://www.youtube.com/watch?v=qlBvYMjoWf4
anton Tue 02 June 2009 05:24
Limit switch inputs
Hi Gerald,
Do the limit switches feed into the breakout board spare inputs, and are they used in the mach 3 program? :confused:
Anton
Gerald D Tue 02 June 2009 05:30
Yes, the limit switches are all in series with each other and only use one input into the breakout board for Mach to use.
smreish Tue 02 June 2009 12:53
The proximity wiring thread is here. for reference.
arcgenie Tue 23 February 2010 09:47
Hi Gerald,
Please can you send me the complete Electrical & Electronic Plan of MechMate Machine.
MetalHead Tue 23 February 2010 09:53
http://www.mechmate.com/forums/showt...00&postcount=1
Drawings are here.
Details will need to be researched in the forum.
arcgenie Tue 23 February 2010 10:09
Thank you MetalHead
I need just the complete & Electrical & Electronic Plan
The drawing in :
are not complete, I'm new in electrical
Gerald D Tue 23 February 2010 10:32
You need to draw your own complete & Electrical & Electronic Plan based on the motors, drives, "breakout card", power supply that you will select. Each of those components have their own requirements from their manufacturers - it will help you if you select components with good clear instructions.
arcgenie Tue 23 February 2010 10:43
Thank Gerald,
Can you send me the global Plan (or the drawing example) that explain principal Control Systems of the machine ?
Gerald D Tue 23 February 2010 11:39
I am going to send nothing to you. You need to spend a lot more time reading the stuff already here on this web site.
arcgenie Wed 24 February 2010 15:57
Ok Gerald
cncb Mon 01 March 2010 21:36
There is so much valuable information here on electrical stuff/controllers/geckos/BOBs. I've been here quite awhile and I'm still finding threads I haven't read yet. Best bet is to read read read and then read some more. If you see something or a term you don't understand or why something was done one way electrically the best bet is to google it, look it up and get a full understanding before doing anything. A clear concise plan can go a long way, and you should feel confident before you land a single wire.
Red_boards Sat 28 May 2011 21:02
I found this document on estop for PMDX 125 board and spindle. Neat circuit diagram.
http://www.pmdx.com/Doc/AN125-1_MachinePower_02.pdf
IPenev Sat 06 July 2013 15:10
hahaha, I have been reading for a week and still hesitating of asking stupid questions before I read everything there is :), He wants it over night :)
