Old Thu 18 September 2008, 10:12
PEU
Just call me: Pablo
Buenos Aires
Had a transformer built - Buenos Aires, Argentina
Hi, this is intended to be the future build log of my MM, it may take a long time to have pictures posted, but I started modelling in CAD my future machine, so I will need a place to make questions, this will be that place.
My 3D model is being made in Solidworks, which also has a very nice and free viewer that allows anyone wanting to view and comment my progress to be able to see it without installing the full CAD package.
This free viewer can be downloaded HERE
Here is a photo of what I've done so far:
The biggest board size available here in Argentina is 3050x1850 so I designed around this size.
Main Longitudinal lenght is 3650mm and beams are 200x75mm C channels at 25.5kg/m
Cross bearer lenght is 2270mm with 80x45mm C channels at 8.7kg/m
Table pipes are 50.8mmx3.2mm wall section.
Total weight so far: 520Kg
Now, here I start with questions, please be patient, I suck at reading 2D blueprints and I may be asking stupid questions every now and then
I want to be able to split the machine in parts like Gerald did in this photo:
Once you assemble both sides, are the cross bearers bolted or welded?
Pablo
Old Thu 18 September 2008, 10:21
Bolted
Old Thu 18 September 2008, 14:12
PEU
Just call me: Pablo
Buenos Aires
In 10.10.240 steel angle, the photo shows an already machined profile or I should start with a dissimilar sides L angle?
I can find this profile everywhere here.
Thanks!
Old Thu 18 September 2008, 15:17
PEU
Just call me: Pablo
Buenos Aires
Nevermind, I found the answer in the forums, a month here and I'm still discovering the place
Old Thu 18 September 2008, 18:07
HI Pablo, I can help u with few parts - let me know if you want me to model a few part - give me the part numbers - I use SW2008 though.
RGDS
IRfan
Old Thu 18 September 2008, 19:43
PEU
Just call me: Pablo
Buenos Aires
Hi Irfan, very kind of you
But, if you help me it defeats the purpose of the effort Im taking to draw it, which is learn how to read the blueprints & assemble the machine.
BTW, section 10, the table, is finished, now the fun part begins, the Y gantry, it should be easy, I have all the parts already modeled, mmm, not really, motors & rack/pinion still need to be drawn, but I will leave the R&P till I know what can I find here.
Today I called a couple of steel supliers (both local) and the price differences between them was around 30%
The 200x75x3650mm UPN profile best price was USD235 each, I need to shop more, Im sure I can lower this still more.
Attached is the finished table model.
cheers!
Old Thu 18 September 2008, 20:23
Pablo the table looks a little close to the left end of the rails to me. It could just be the angle of the drawing, double check and see? Can't wait to see it finished so far it looks pretty cool.
Old Fri 19 September 2008, 06:48
PEU
Just call me: Pablo
Buenos Aires
JR, you are right, its maybe a little to the left, I used this image as a reference:
and this was my previous comparative view:
I re-did it and now it looks like this:
Now the rail stops are outside the workspace, I guess this is the correct arrangement
Thanks!
Old Fri 19 September 2008, 07:08
Pablo, have you enabled measurement on the edrawing file? also apply material so that we can estimate the weights of the individual parts.
RGDS
Irfan
Old Fri 19 September 2008, 09:05
PEU
Just call me: Pablo
Buenos Aires
Irfan, I just reopened the file and yes you can measure everything, go to the measuring tape on the left toolbar and once there a new measuring tape icon appears on the middle of the left panel.
Current weight is 550Kg
Old Fri 19 September 2008, 09:17
Pablo, no. 4 cross-support channel from the right . . . . how are you fixing that to the big beam?
I tried to point the cross-support channel legs to the center of the table.
Old Fri 19 September 2008, 09:20
I get the impression that you did not see on the drawing that the table is 100mm off the center of the legs and x-rails? (You seem to be guessing a distance above?)
Old Fri 19 September 2008, 12:09
PEU
Just call me: Pablo
Buenos Aires
I missed that one, I guess because it was hidden behind the leg, already corrected this
You are correct, I saw just today the mention about the centerlines, also corrected this, attached is the new model.
BTW, is ok to keep attaching files? I can host them in my site if you want. I see a red bar in the attachment screen that moves to a full position, how do I remove old/obsoleted attachments?
Thanks!
Old Fri 19 September 2008, 12:11
Unfortunately you cannot remove attachments.
Old Fri 19 September 2008, 22:22
PEU
Just call me: Pablo
Buenos Aires
Not sure if I will be able to draw during the weekend, I advanced a little today, here is a picture and then take a look at the attachment. Curious minds will look for the animation button
I hope fit is the same in the real world, CAD models provided by Gerald are purrrrfect!
Pablo
Old Fri 19 September 2008, 23:36
Do you want me to delete some of your older attachments, or posts?
Old Sat 20 September 2008, 08:18
PEU
Just call me: Pablo
Buenos Aires
Feel free to delete old attachments, I wanted to spare you this job, but it seems VBulletin is configured to not allow edits after a day or so. The latest attachment includes work done in previous posts.
Delete posts? did I say something improper? Im sure I asked some dumb questions already, but its part of the learning process
cheers!
Old Sat 20 September 2008, 08:30
I have configured this vbulletin so that users cannot delete their attachments. However, I will delete things on request. Sometimes, if only the attachment is deleted, then the post no longer makes sense - that's why I offered to delete posts as well. (It is easier for me to delete a whole post with attachment)
People who have posted a lot of stuff get their limit increased - but there is always a limit. (Sometimes I copy a post to another thread, and that chews into your limit because an attachment is then posted twice.)
Old Sun 21 September 2008, 22:29
Comment on post #15.. I think the Y-car should turn 180 degrees..your long side of the table is on the right hand side of this drawing. If you fit your router/spindle to view it from the right hand side, then the car is wrong on this impression....I think...otherwise very nice to see it like this, wish I had it like this when I did my build.
Old Sun 21 September 2008, 23:13
Kobus, that view looks right to me.
Old Mon 22 September 2008, 01:19
You are right again...0.0 will be on the top left hand side on that drawing......that is why I said.... I think....I should not THINK.
Old Mon 22 September 2008, 04:05
To make it clear:
Old Mon 22 September 2008, 07:35
In this view . . . .
. . . . . you should see M1 30 332 P. The y-motor goes on the other side.
Old Mon 22 September 2008, 20:40
Nice model. I wish it had been produced when I was building.
Old Tue 23 September 2008, 03:18
Pablo
Very nice drawings. You are doing an excellent job.
Old Thu 25 September 2008, 11:15
PEU
Just call me: Pablo
Buenos Aires
Thanks for the nice words, been busy these last days, I will start drawing the Z axis in a few days
Old Mon 29 September 2008, 14:16
PEU
Just call me: Pablo
Buenos Aires
I started drawing the Z axis, I have one question (maybe more to come)
why 10.40.334 is not laser cut?
I mean, I can ask this piece to be cut from heat hardenable steel if needed.
And to make things simpler (at least for me) I own a small CNC mill (*) I can use for drilling holes before hardening them
Or Im missing something here?
Thanks!
(*) I represent Syil CNC machines here in Argentina.
Old Mon 29 September 2008, 21:13
I very much doubt that you can get that part cut economically from a "tool steel" from a standard laser supplier. Get us some prices and then we can talk again.
Old Wed 01 October 2008, 16:58
PEU
Just call me: Pablo
Buenos Aires
Question regarding M1.20.210 excentric bush: whats the purpose of using excentric bushings vs. a concentric one?
Thanks for un-dumbing me
Old Wed 01 October 2008, 19:57
Pablo,
Eccentric bushings allow you to do two things. 1) You can tighten up the tolerances between the V-rollers and the Z axis. 2) You can adjust the Z axis so that it is perpendicular to the table.
The way you do that is by using a wrench on the hex head of the bushings until they are in the right position and then you tighten the allen head bolts that pass through them. Very ingenious engineering on Gerald's part.
And another MM will be built in Belgium bramvh Introduce yourself and start planning 9 Fri 15 April 2016 14:01
It's alive and cutting! - BS AS Argentina zumergido MechMates already cutting 40 Sun 18 November 2012 15:49
Frame built and primered - Joburg, South Africa Brad Maritz Construction started, but not cutting yet 48 Tue 08 March 2011 09:21
The MM is built. Now what ? - Building the business on 5 questions gixi Miscellaneous / General / Whatever / Catchall 1 Tue 13 October 2009 10:07
Two MM's being built in Delavan, WI and McHenry, IL Delamination Construction started, but not cutting yet 34 Mon 19 January 2009 07:32
