Old Thu 04 September 2008, 21:24
YRD
Just call me: Yuri #17
Brasilia - DF
Brazil
Trying smaller motors with belt reduction #17 - Sao Caetano do Sul, SP, Brasil
Hello,
My name is Yuri and I Sao Paulo - Brazil (with "s" rather than "z") .
I thank Gerald for creating this wonderful project.
Forum on CNC in Brazil - CNC Guide - http://www.guiacnc.com.br/forum/inde....html#msg61547
Some pictures:
Old Thu 04 September 2008, 21:30
Welcome Yuri!
Looks like you are on your way. Keep us updated with photos, we like photos.
Old Thu 04 September 2008, 23:18
Welcome to this forum Yuri!
I see you are going to have quite a big X dimension: 4400mm [14.4 ft]. What is your Y dimension?
Old Fri 05 September 2008, 00:22
Good luck with the building of your MM. I like the clean W/Shop and new tools..
Old Fri 05 September 2008, 17:17
YRD
Brasilia - DF
Brazil
Thanks Domino, more photos
License to change his project.
Y original 2350
My roller: http://www.yi-tong.com/
Purchased in Brazil for about U.S. $ 35.00
You already knew this manufacturer?
Here are several taxes . For you to be less
Old Fri 05 September 2008, 17:44
YRD
Brasilia - DF
Brazil
My monster
Old Sat 27 September 2008, 20:56
YRD
Brasilia - DF
Brazil
Cool Laser cutting
Laser cutting and CNC Bending.
I am happy and nothing like a beer to accompany
Old Sat 27 September 2008, 21:54
Hi Yuri, Looks like you ordered a couple of extra parts?
Old Sat 27 September 2008, 22:34
YRD
Brasilia - DF
Brazil
Hi Gerald,
Yes
The company that made the cut has a minimum value for the service. Approximately US$ 270.00
If commit any errors in the solder, can change the play.
What did you think of V-Roller chinese
Old Sat 27 September 2008, 23:32
V-Roller chinese should be okay.
Old Mon 29 September 2008, 06:33
YRD
Brasilia - DF
Brazil
In the post 9 reads "solder" read welding.
Problem of translation.
Old Mon 29 September 2008, 09:23
Yuri,
No problem, I knew what you meant, even up here in Canada!
Old Mon 29 September 2008, 12:43
YRD
Brasilia - DF
Brazil
Hi Heath,
Excuse my poor English
AND YOUR photos? I think it's legend
Old Mon 06 October 2008, 19:02
YRD
Brasilia - DF
Brazil
More pics
Now we are going to paint
Old Mon 06 October 2008, 19:06
YRD
Brasilia - DF
Brazil
Pics
Old Tue 07 October 2008, 04:53
Yuri, I love your new …. Kitchen table
Robert
Old Tue 07 October 2008, 05:34
That artwork in the corner is especially interesting!
Old Tue 07 October 2008, 10:24
YRD
Brasilia - DF
Brazil
Modern Art
Old Tue 07 October 2008, 10:32
YRD
Brasilia - DF
Brazil
Robert
Is where my wife tells me to sleep
Yuri
Old Wed 08 October 2008, 20:06
YRD
Brasilia - DF
Brazil
Gantry
Start
Old Wed 08 October 2008, 23:38
Ah, those tubes are at least 3mm thick, but still not thick enough to tighten the M8 screws really tight in a tapped hole. Are you adding something inside? Or, are you going to be careful with the tightening? I think it is okay for strength of the rail joint if the tightening of the screw is at half-tightened . . . . .
Old Thu 09 October 2008, 07:44
YRD
Brasilia - DF
Brazil
Yes the bar of steel inside the tube, as project.
Old Thu 09 October 2008, 16:54
YRD
Brasilia - DF
Brazil
Cut 28mm
How should I use for 28mm?
Use the blade as in the 1st or 2nd picture?
Yuri
Old Thu 09 October 2008, 22:19
Hi Yuri, I think you have the wrong disk for cutting the rail down to 28mm. Your picture looks like a GRINDING DISK. You need a CUTTING DISK. I used a very thin one to cut done my rails. When you grind something, the setup in photo 2 is correct according to me....Correct for grinding the 45 degree bevels on top of the rail.
http://www.mechmate.com/forums/showt...8&postcount=27
Pferd SG-Elastic INOX-Stainless 1mm disks.
Old Thu 09 October 2008, 22:36
YRD
Brasilia - DF
Brazil
Thanks Kobus for post,
But,
Specification of Norton Brazil - BDA 08:
http://www.norton-abrasivos.com.br/D...00000000005035
Disc Cutting 0,8mm Carbide Silicium
Old Fri 10 October 2008, 03:29
Hi Yuri, the disk looks okay. (use as per second pic). Interesting that you find such a thin disk with a "cup" (hollow) in the center. I only know thin disks that are completely flat.
Old Fri 10 October 2008, 06:18
YRD
Brasilia - DF
Brazil
Hi Gerald,
I have the option completely smooth and 0.8 / 1.0 or 1.6 mm (thickness). Which to choose?
Kobus you cut the 28 mm with "skate" supported by only 4 screws? Nothing else? He ran the skate supported only by hands?
What is the best option for a man cut the 28mm?
1 - Cut as Kobus (sliding skate cut)
2 - Cut Fixed (skate fixed on the table)
Old Fri 10 October 2008, 06:55
Yuri, I clamped the rail on my table saw top. Then only supported by hands cut a short piece. Then move rail and cut the next piece until finished.
I must say I have never seen thin cutting disks with a CUP in the middle, that is why I thought they were grinding disks.
Old Fri 10 October 2008, 08:11
Yuri, I like the method of Kobus (and Hennie) . . . . Fix the rail down to a horizontal table, and then use sliding skate. First take light cuts to make a shallow groove and then use more force to go deeper. Move the skate forwards and backwards a lot, so that you never cut hot steel - always cut cold steel.
"I have the option completely smooth and 0.8 / 1.0 or 1.6 mm (thickness). Which to choose?"
I do not understand the "completely smooth" part? In general, the thinner 0.8 should be the best, but start with very light cuts to make the first groove.
Old Fri 10 October 2008, 09:21
YRD
Brasilia - DF
Brazil
I have flat disc or CUP at 0,8 or 1,0 or 1,6mm.
Better flat disk or CUP disk ?
