Closed Thread
Old Sun 03 February 2008, 23:18
westlc01
Just call me: Westy
Adelaide
Process Codes appearing on drawings
Hi everyone, first post after doing a fair bit of reading.
I have noted that the Drawings all follow a numbering sequence that is easy to understand. I also have established that if I sort the Drawings by process number I can outsource work lots and it is a nice way of logically managing the project.
What I would like to confirm is the Process Codes. Could someone point me to a forum post or comment on my best guess?
A - Assembly
T - Turning
W - Welding
D - Drilling
B - Bending
P - Profiling
S - Sawing
M - Milling
G - ??? Grinding (10 10 324 and 10 10 334)
K - ???? (M3 10 100)
C - Circuit
Thanks Craig
  #2
Old Sun 03 February 2008, 23:37
A - ASSEMBLY, NORMALLY CAPABLE OF DISASSEMBLY
W - WELDED
S - CUT BY SAWING FROM "LENGTHS" STOCK
G - CUT BY GUILLOTINE FROM SHEET STOCK
K - SPRING
T - TURNED ON A LATHE
D - DRILLED, WITH OR WITHOUT TAPPED THREADS
M - MILLED
P - PROFILE CUT, TYPICALLY LASER
H - HARDEN, HEAT TREATED.
B - BEND
C - CIRCUIT
  #3
Old Mon 04 February 2008, 00:00
westlc01
Just call me: Westy
Adelaide
Thanks Gerald.
And fantastic work by the way.
Closed Thread
