Old Mon 21 January 2019, 16:52
Diplocaulus
Just call me: Gary
Kearney
Huanyang bit the dust, replaced with Lenze, question about parameters...
Hello, a transformer in the Huanyang blew, so we decided to go with an actual warrantied Lenze VFD from Precision Electric. I added 2 inline fuses to the VFD, wiring is basically ready to go on the mains side, but I have two questions; How do I know which motor connector goes where, the manual doesn't label individual wires apart from ground. It shows "Motor 3~" and just leads them to the motor inputs. I sort of take this to mean it's unimportant which goes where but this seems unlikely. I can talk to them about that on the phone tomorrow, so more importantly how do I know which parameters to set to make mach3 play nice with the vfd? This vfd has 300 parameters and I know I don't need all of them, I tried to correspond them to the set parameters for the Huanyang but they are juuuust different enough to confuse me on some of them. Is this something I figure out on the VFD side or should I be looking more at mach3 to figure it out?
Old Mon 28 January 2019, 14:18
Its not important UVW, after first motor start , check the CW direction , if its not correct swap one pair of wires that go to the spindle
How did you control the Huanyang, with plugin or 0-10V and FWD command with relay output?
Setting up a Huanyang HY02D223B VFD Jayson 701. Motor Drives 20 Fri 02 November 2018 07:25
Mach3 plugin for Huanyang VFD racedirector 50. Toolheads 1 Tue 08 July 2014 04:59
Sold...(replaced by heavy Thermwood) #88 - Alberta CAN John Saunders MechMates already cutting 19 Mon 19 November 2012 07:14
HuanYang VFD, A.K.A. The Cheap Chinese VFD KenC 50. Toolheads 37 Thu 26 August 2010 13:10
Dust-proofing stepper motors and consequences of dust ingress Doug_Ford Motors & their mountings 25 Thu 08 November 2007 19:09
