Old Fri 22 November 2019, 05:21
IamDave
Just call me: Davey
Ball Ground, GA
No, no filtration. This fan actually creates a breeze through the box, and blows out.
I used aluminum tubing, and a screen mesh, as my heat sinks. Filtration filter was a thought. I may add it later, if needed.
Old Wed 11 March 2020, 05:58
IamDave
Just call me: Davey
Ball Ground, GA
Does anyone cut 1 inch mdf or extira on a regular basis, with their machine?
Old Sat 21 March 2020, 06:24
IamDave
Just call me: Davey
Ball Ground, GA
Figured it out. Was just cutting to fast, losing steps here and there. Experience can have it's cost. Wore out the bearing in my first spindle, two bearing. Spindle cut about 450 sheets of extira. Not bad for a 200 investment. Well worth it for the savings in broken bits using the porter cable setup.
Old Sun 22 March 2020, 09:28
IamDave
Just call me: Davey
Ball Ground, GA
It's like a ghost town around here, in N. Ga.
Old Wed 22 December 2021, 12:31
IamDave
Just call me: Davey
Ball Ground, GA
Out with the Old-----In with the new.
Well time has come, as planned. My little 4x4 build is growing. After cutting close to 8-900 sheets of 1-inch Extira and plywood, and lots of bits and mistakes... I took it apart this week. Going to build her back soon bigger. Learned a lot and gained a lot of knowledge, I didn't have before. It was still sad to take apart, after all the work I put in it.
Ball Screw For Sale Francois The Market Place 1 Mon 06 February 2012 23:25
Ball screws Richards Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 1 Sun 28 August 2011 07:31
hobbed or ground rack? southernduckie Rails & Rollers 11 Thu 26 May 2011 08:36
Round shafts & ball slide blocks versus V-rails & V-wheels joepardy Rails & Rollers 28 Fri 07 December 2007 12:41
