Old Thu 18 July 2013, 20:31
hevertg
Just call me: Hevert
maracaibo
Venezuela
Welding Up The Table!- Maracaibo, Venezuela
hello, greetings MechMate lovers. excellent forum not stop reading, I'm from Venezuela and empese and buying parts,
yesterday buy the rack and pinion Module 1.0 8 mtrs in total cost me 529 dollars in canada buy them in this store: http://www.motiontek.ca/index.html
next week I'll be buying the engine and driver: the engine is this and chose the driver:
NEMA34 640 oz-in Stepper Motor 4.5A (KL34H280-45-4A)
Gecko G203V Stepper Driver 80V, 7A
http://www.automationtechnologiesinc...ko-driver-g23v
please if you have some recommendations for me, I beg the help.
preferably paypal payments, currently HAVE A 1200 dollars to buy the driver and motor
my project with MechMate is create one that can use it with: rauter plasma cutter.
greetings to all the forum especially the forum Gerald_D excellent job creator friend, and I have time for here, did not have the money for expensive invercion is right now in my country, but I can and I started already.
thanks hope some comments that might help me at hello.
pardon my English use a translator
Old Mon 22 July 2013, 13:09
isladelobos
Just call me: Ros
Canary Islands
Spain
Felicidades por ese comienzo, me apunto a seguirte en tu construcción.
Como puedes ver yo tengo la mía under construction desde hace miles de años, a ver si le doy un empujon.
Supuestamente tu mesa es de 3x2 metros
Saludos.
Old Mon 22 July 2013, 13:46
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Pa'lante maracucho
if you need help I'm in Curacao, next you
Old Mon 22 July 2013, 14:57
paulus
Just call me: paul
jhb
Hi hevert
Welcom and you will have a lot of fun building the MM
Old Mon 22 July 2013, 17:43
hevertg
maracaibo
Venezuela
saludos
erga ahora es que hay de los nuestros por aqui, jajaja
isladelobos yo tambien tengo rato tratando pero sabras con es la cosa aqui en venezuela con los dolares jajaja, si quiero una grande
parrulho panita y tu tienes MM? que compraste por venezuela? en bolivares jajaja, me avisas si hay algo para comprarlo de una.
paulus ty
bueno yo ya empese a comprar partes ya me compre los rack y pinon que costaron como 570 dolares en canada, ahora voy por los motores y los Gecko G203V pero estoy esperando que paypal me permita comprar no he confirmado las tarjetas se tarda aveces. bueno muchachos saludos
Old Tue 30 July 2013, 10:55
hevertg
maracaibo
Venezuela
hello, greetings, please'm buying today the engines, but I hesitate queiro help me to choose the engines. I can not buy me the 7.2 are very expensive for me. but I can buy these:
whom I recommend them? I buy them? I want to learn to pick my engines, but do not understand many things even though I read a lot in the forum, if someone gives me an instruction I would read all the to to understand for myself and to help others in the forum, greetings hope can help.
Old Tue 30 July 2013, 16:36
isladelobos
Just call me: Ros
Canary Islands
Spain
Helvert.
Motors & their mountings
I have the motionKing motors.
Old Tue 30 July 2013, 17:11
I have the more expensive motors but I would buy the motionking motors and build belt drives.
Old Sun 11 August 2013, 21:32
hevertg
maracaibo
Venezuela
good, buy you steel this week to start working with my MM, future numbers? lol, I will try to be as accurate as possible to the original, I did some drawings that are perfect for construction because you can take action and everything. Google SketchUp is very good.
I have the files in Google SketchUp if somebody wants me know
Old Mon 12 August 2013, 00:33
parrulho
willemstad
looks good.
Old Wed 14 August 2013, 20:02
hevertg
maracaibo
Venezuela
hello sir, I tell her as I go with my purchases:
I bought all this: PS-8n63, PMDX 122 34HS9801, rack and pinion, laser cuts mike, gecko drive 203V, Spindle 2.2, 3:1 gear XL, I can buy you more than I need?
Old Thu 15 August 2013, 23:27
hevertg
maracaibo
Venezuela
hello, I need help, I can use UPN 240mm Beam profile for rails X?
Old Thu 15 August 2013, 23:54
If you are buying from Deitech, do get extra length of rack. You might have to discard 2~3inches of the ends. Even so, its still a bargain...
Old Fri 16 August 2013, 00:08
hevertg
maracaibo
Venezuela
10 10 320
hello friend, do not speak of the rack, and buy 7.5 meters, I'm talking big steel rails October 10 320.
in my country it is difficult to find 10 10 320 steel. I found one but 3000mm * 240mm * 75mm, if that's okay? or is very heavy and big?
Old Fri 06 September 2013, 18:59
hevertg
maracaibo
Venezuela
screws
hello, greetings where I can buy these screws
Old Sat 07 September 2013, 00:58
Nothing wrong with 75x240x300mm. Some of us here like it big and heavy.
Is that for the W-wheel? Is it a screw with built in concentric bush? You can use the if you like but a simple screw works just fine.
Old Sat 07 September 2013, 10:18
hevertg
maracaibo
Venezuela
hi ken, thanks for your answer, if I have the opportunity to put a single screw, but I want to be more Cadre, I would buy those screws, just not where to buy them? you can say that I find? I have searched a lot.
Is that for the W-wheel? yes
Old Thu 14 November 2013, 10:14
hevertg
maracaibo
Venezuela
[IMG][/IMG]
greetings, people MecheMate. my toys are arriving to start divercion lol
where you can find information on how to connect:
PMDX 122 + 34SH9801 + G203V + PS8N63R12
Please need help
Old Thu 14 November 2013, 10:28
hevertg
maracaibo
Venezuela
[IMG]
Old Thu 14 November 2013, 16:34
parrulho
willemstad
Hevert, it's all on plans and here at the forum. send me an email with your questions and I'll help you (in spanish).
paulo
Old Wed 27 November 2013, 15:21
hevertg
maracaibo
Venezuela
MechMate Hello friends, I'm in my test control box, but I have a problem and my 34HS9801 8 wire motors: Amariya, blue, green, orange, red, white, black, brown. ok in the planes of the MM, connect (Red and Yellow Phase A + A-phase) (Black and Orange Phase B + Phase B-) ... Now what to do with the other 4 wires: Blue, White, Brown, and Green?
Old Wed 27 November 2013, 16:23
hevertg
maracaibo
Venezuela
Old Wed 27 November 2013, 16:25
hevertg
maracaibo
Venezuela
Help is well connected?
just to test that everything works
Old Fri 29 November 2013, 21:50
Looks like you need your resistors on the geckos and you have a look at your other 4 wires on the steppers, how are they to be wired? Bi-polar series, bi-polar parallel or unipolar, you will have to pair them properly, its the set up you used to help you choose the power supply. I haven't really looked at the other wiring.
Old Sat 30 November 2013, 21:50
hevertg
maracaibo
Venezuela
hello tom: half coil
had an error with the black wire, and change it to white, it caught all good, but when you connect the parallel port, the plate 122 pmdx led all turned dull, turn it off and went back to fast on and lit a fire ship in the plate
and i do not know why I spend so conctado if everything was ok, the problem arose when connecting the cable from the parallel port,
has the parallel port cable original cable some different settings?
I probe the small connector db25 pin 20 and all had good continuity.
I could go there?
two images: 1 all working, and the other the ship burned.
Old Sat 30 November 2013, 22:11
Are you saying that your board burned up? that wouldn't be good. In the picture of posting #23 I see no resistors on the gecko drives, have you put the resistors on? Does the PMDX 122 have a 'test mode' you can run? If it does you will want to run it first before connecting to the computer. I have the PMDX 126 which does have a test mode set up. Find the wiring diagram for the steppers and wire them accordingly. http://www.mechmate.com/forums/showt...f+coil+winding 2nd or 3rd posting down. Good luck.
Old Sat 30 November 2013, 22:44
hevertg
maracaibo
Venezuela
UNIPOLAR
[IMG][/IMG]
if he seems the pmdx 122 is burned, if the resistance be installing the morning, pmdx 122 has test mode? I do not know friend, you know how? of 8 cables connected only have 4 in this image: a-a / / b-b, red and yellow .. white and orange
Old Sun 01 December 2013, 06:14
If you have 8 wires, pair them like the first image, if you have only 4 wires then they will likely be directly connected to the drivers.
Your manual for the board should have the information about test mode(s) if any available.
Page 6 of your manual shows an example set up, that's all I can recommend for the board to drivers connections, like I said, I do not have the 122. If all does not work, you may need a new board.
You will have to look at the geckos for the resistor values, the steppers help determine the amperage required to operate properly. Again I did not use geckos so you will have to find the information throughout the forum, in your manual, or on a support website. Sorry but I can not help you on this part.
Old Sun 08 December 2013, 20:21
hevertg
maracaibo
Venezuela
Cutting
starting cuts for my MechMate, I hope to finish it quickly, I'll be putting pictures of my progress
will of 3100 x 2200
[IMG]
Cutting
[/IMG]
Me
3ub.jpg[/IMG]
Fair cut
I LTD50 LOTOS Plasma Cutter, very good
Old Mon 09 December 2013, 03:14
That's a nice clean cut. Keep up the good work.
Welding up the Table - Pretoria S. Africa CoRn3 Construction started, but not cutting yet 73 Sun 13 March 2016 04:39
Waterjet Project - Puerto Ordaz Venezuela Guillermo Introduce yourself and start planning 61 Fri 02 May 2014 17:54
MM Amazonas/Venezuela alexguan Introduce yourself and start planning 0 Wed 19 May 2010 06:50
CNC para Venezuela suzuki039 Introduce yourself and start planning 4 Thu 04 February 2010 19:26
Welding Table Legs - Othello, USA weldnh20 Construction started, but not cutting yet 23 Sun 25 October 2009 18:13
