Old Sun 25 May 2014, 16:59
jd.roberts
Just call me: JD
Mesa, AZ
Parts no longer for sale.
Hi everyone, well as my post says it's all got to go. I have almost everything to build a nice Mechmate. I thought I would have time to finish it and sell it as a complete unit.
I ended up buying a gently used CNC Router, so now I don't have the time or space.
I would like to make someone a package deal on all of it. If not I will part it out in 30 days. I'm open to discounting the prices but I'm not desperate. So please be realistic. If your local or want to pick up I have all of the steel for the table available.
All parts except laser cut kit are new in box or packages, buyer to pay actual shipping costs.
*Mechmate plans printed in binder and PDF file. $100.00We don't resell plans
*Metal Mike’s basic laser cut kit - Monocque car is welded and done. $520.00
Extras:
*Machine leveling feet - included
*Rail Grinding Skate – included
*Correct fit Dewalt grinder for skate new in box $60.00
*Stop Blocks $42.00
*Idler Stub Shaft and Bushings $105.00
*idler bearing for the Idler Shaft $15.75
*Motor Belt Drive Plates- welding and bending done $132.00
*MM Logo Decals - included
Mechanics:
*Metal Mike’s belt drive kit 3:1 $462.00
*Boston YA30 Pinion Gears Steel 20 Degree Pressure Angle Spur Gear, 20 Pitch, 30 Teeth, 1.5" Pitch Diameter, 1/2" Bore $90.00
*BWC Bearings Mechmate kit includes all V-Bearings and Cam bearings
GW3 14 pcs
GW3 6 pcs $246.16
All electronic parts are new wrapped in package:
*Metal Mike’s basic control box $446.00
*Metal Mikes’ Remote Control Panels (2 Sets) $142.00
*KL34H280-55-4A Motors X4 $340.00
*4 203V gecko's $556.00
*PMDX 133 $49.00
*PMDX 126 $174.00
*PMDX 107 $57.00
*HD Heatsink $95.00
*All cables for PMDX boards $15.00
*All Cable for machine Motors-Controller etc, not cut- enough to do a 5X10 machine. $300.00
*Torrid transformer $50.00
*2 Mallory 23Kuf caps $25.00
*3M double sided VHB rack tape $55.00
*Teflon motor washer kit $22.00
Total retail $4098.00
$3500.00 takes it all plus shipping
I'm sure I didn't list everything but it needs your labor, nuts and bolts, Pinion rack, Z tool steel, Mach and a router/spindle to be a complete machine.
This combo should make a nice Mechmate that is fast and accurate with plenty of torque.
JD
Old Sun 25 May 2014, 19:30
rcboats1
Just call me: Kelly
Everett (WA)
If you decide to part it out I will take,
Old Sun 25 May 2014, 21:12
jd.roberts
Just call me: JD
Mesa, AZ
Hi Kelly,
I was really hoping to unload it as a package deal, however, I actually got an email from a Mechmater that said I'd do better parting it out...I'll give it some consideration.
JD
Old Mon 26 May 2014, 04:52
Sorry to read you have to let it go.....
Wishing you a turn of events.....YOU never know
Good luck
Old Mon 26 May 2014, 05:27
I am sorry to see you having to sell your stuff. But please note that you can not sell the plans. Builders need to buy their own when building a MechMate.
Old Mon 26 May 2014, 09:29
jd.roberts
Just call me: JD
Mesa, AZ
Hi Mike,
noted and understood, please remove this line from my posting:
JD
Old Thu 05 June 2014, 11:07
jd.roberts
Just call me: JD
Mesa, AZ
20% of all MM parts
Hi every one, I have decided to part out my parts collection, all prices are reduced by 20% or more. I’ll remove from post as items sell. PM me if you'd like to buy anything.
*Machine leveling feet – $30.00
*Rail Grinding Skate – $25.00
*Stop Blocks $35.00
*Idler Stub Shaft and Bushings $85.00
*idler bearing for the Idler Shaft $12.00
*Motor Belt Drive Plates- welding and bending done $100.00
*MM Logo Decals – $5.00
Mechanics:
*Metal Mike’s belt drive kit 3:1 $375.00
*Boston YA30 Pinion Gears Steel 20 Degree Pressure Angle Spur Gear, 20 Pitch, 30 Teeth, 1.5" Pitch Diameter, 1/2" Bore $60.00
*BWC Bearings Mechmate kit includes all V-Bearings and Cam bearings and bolts
GW3 14 pcs
GW3 6 pcs $200.00
*Metal Mike’s basic control box $370.00
*Metal Mikes’ Remote Control Panels (2 Sets) $125.00
*KL34H280-55-4A Motors X4 $280.00
*4 203V gecko's $480.00
*PMDX 133 $40.00
*PMDX 126 $150.00
*PMDX 107 $45.00
*HD Heatsink $65.00
*All cables for PMDX boards $10.00
*Torrid transformer $30.00
*2 Mallory 23Kuf caps $15.00
*3M double sided VHB rack tape $40.00
*Teflon motor washer kit $15.00
JD
Old Sun 08 June 2014, 09:06
Foam
Just call me: foam
Dallas
parts
I would be interested in buying the entire lot. Please give me a reply.
Old Tue 15 July 2014, 11:46
jd.roberts
Just call me: JD
Mesa, AZ
I have decided to build the Mechmate after all.
Old Tue 15 July 2014, 13:16
Glad to read you've found a buyer...
Now let the fun begin ....
Enjoy !
Mechmate parts for sale in Norway soulvoid The Market Place 4 Fri 13 September 2013 08:42
Mechmate Parts for sale w/photos. Finally stphnd22 The Market Place 14 Wed 07 September 2011 20:25
Laser cut parts for sale hack Archives 3 Fri 15 July 2011 07:29
For Sale - selling all my Mechmate parts I have David S The Market Place 25 Mon 04 April 2011 21:47
