Old Wed 14 May 2014, 13:05
Helsingtwelve
Just call me: James
Houston
How to run a Gcode X amount of times
Hi I'm running Gcodes on a small machine using my control box that is the only thing I have finish, and I trying to cut letters (Fonts) from a 1/4" plywood but I need to make the cuts continue progressively instead of having to run then stop and run again deeper down I have broken 4 bits like this.
I'm converting the DXF using (FlashCut) and I would like to know if there is a feature in Mach3 to run Gcode or repeat X amount of times in one single run.
For example run X amount of times is 1/4" deep, run in 4 continuous passes of 1/16" increments
Thanks in Advance
Old Wed 14 May 2014, 16:35
You could use the multipass wizard.
Old Wed 14 May 2014, 22:01
Why not just edit the G-code file? copy & paste, & edit the nex Z.
Old Thu 15 May 2014, 08:43
My thought exactly, Ken.
Old Thu 15 May 2014, 08:47
I use the LAZY CAM engine available as an option with MACH and it has a multipass feature too. The nice part it is it will open a Gcode.tap file and reverse engineer the file, you edit, then play again almost immediately.
Best 75 bucks I spent that year.
Note - I KNOW for sure that Vectric Cut 2D does this as well and far easier/better. And it's only 150.00
Old Thu 15 May 2014, 09:10
ger21
Just call me: Ger
Detroit, MI
I'd stay far away from LazyCAM and get a real, finished, and supported CAM program. At the low end of the price range, either Cut2D or CamBam.
Old Thu 15 May 2014, 10:27
...there is a reason it's called LAZY!
Personally, love Cut2D and Cut3D for cost and usability.
Use them both often.
Gcode for spiral circles. rocky2889 CNC motion control software 6 Sun 10 October 2010 18:43
Position accuracy & torque of stepper before slip & slip amount Gerald D Motors & their mountings 0 Wed 15 July 2009 02:05
Gcode for surfacing table DMS CNC motion control software 2 Sun 12 October 2008 09:09
