Old Sat 15 February 2014, 14:16
litemover
Just call me: Chris
Auckland
New Zealand
Cutting Aluminum foam core
Does anyone happen to know if a Chinese spindle, 4kw, would be able to handle cutting 1/8" aluminum foam core board? I have one small project I need to cut some windows out of it and bend it. The aluminum looks to be super thin and I'm sure that others cnc it, I just don't want to risk any bearing problems on my router.
Any ideas?
Chris
Old Sun 16 February 2014, 03:41
Quadro
Just call me: Anthony #77
South Australia
I've just come inside from cutting 3mm PVC sandwiched between aluminium (ACM), I guess foam is easier.
I use a 3kw spindle, 2mm single flute at 800mm/min. If I was using a larger bit I would cut faster.
Add a bit of air for cooling and leave the protective cling plastic on until after cutting seems to pull the 'hairy' stuff off.
Good luck
Old Tue 18 February 2014, 00:26
litemover
Just call me: Chris
Auckland
New Zealand
Thanks! What are you setting your spindle speed at? Also down ur or upcut o flute?
Old Tue 18 February 2014, 13:27
Quadro
South Australia
Spindle speed fastest (I don't know exact rpm). Up cut bit.
For miter joints i use a modified 90 deg cutter on the fold lines and cut not quite all the way through.
To modify the 90 deg cutter I just ground the tip of so that there was about 0.5mm flat.
Old Tue 18 February 2014, 16:52
litemover
Just call me: Chris
Auckland
New Zealand
Very nice! Do you place the presentation face face up or face down? Looks fantastic! Thanks for the help.
Old Wed 19 February 2014, 02:41
Quadro
South Australia
Cut face down.
Old Wed 19 February 2014, 15:59
4mm single flute + 90 degree 2mm flat point
up to 4000mm/min
tips on foam mold creation, types and cutting tools smreish Cutting various materials - bit selection, feeds, speeds 6 Mon 11 April 2011 10:23
Best R+P combo for precision aluminum cutting Stepinwolf Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 7 Thu 07 January 2010 20:07
Cutting Foam Core Board jhiggins7 Cutting various materials - bit selection, feeds, speeds 3 Fri 17 April 2009 13:26
Is the MM the right machine for Me? (cutting thin boards and thick foam) 1foamimprovement General - MM Build 5 Wed 18 February 2009 18:24
Help me to choose a foam cutting CNC machine! kotys2 The Market Place 3 Wed 03 September 2008 17:33
