#61
Ha. Just found it.
I need to compare what I already have and then get the rest. Need motors and power supply for sure. |
#62
Welcome back, knucklehead!
I may have to add a second gantry to mine. Retirement isn't working out so well. |
#63
I may need to come visit you again.
Just a warning. |
#64
Anytime.
Mid January I'll have a BlackTooth Laser added to the arsenal. |
#65
Is that the reason for the second gantry?
#66
No.
#67
Is it free standing then?
#68
Opinions needed.
Wirefeed welder versus arc. Any reason one is superior? Getting ready to buy. Looking at a Hobart http://www.northerntool.com/shop/too...PRwaAhmC8P8HAQ |
#69
I used a stick welder for the base table and gantry, and a wire feed MIG for the Y. car.
The blackTooth is a stand alone machine. |
#70
That welder you linked to is actually a very good welder for the price. Additionally, you can get spool gun for it and weld aluminum as well.
Good luck |
#71
Question.
I have a large supply (200 ft) of heavy wall 2 and 3" pipe. Am I being pennywise and pound foolish to consider using it for the base structure? |
#72
That Hobart is a nice machine.
https://www.millerwelds.com/equipmen...021572-no-name This is a nice welder also. I have a 185 (older Version) and I added a spool gun (for aluminum welding) . Miller and Hobart are owned by the same company since 1996 http://www.hobartbrothers.com/about-...of-hobart.html So a lot of cross brand (Think Chevy vs Cadillac) You should invest in the most welder you think you will need. Not just for the MM build. I have a 252 and it does all I ask it to do. https://www.millerwelds.com/equipmen...illermatic-252 |
#73
Round pipe for the legs and cross bearers are fine
#74
Ordered my welder. Getting the Hobart.
Motors next. |
#75
Make me proud Pete.
#76
Yes
I can get started on my tabletop project. Transformer and steppers are here. I will finally be able to put the parts I got from Darren Sayler to use. |
#77
EXCELLENT!!
Remember, you eat an elephant a bite at a time..... You'll never find the perfect time to build it, so stay on it and break it down into manageable steps you can steal a few minutes a day to complete. |
#78
Tony and I spent a couple hours tonight looking at Geckos and such as well as your electric box. .
The antek transformer I received did not have the 2 orange wires yours show, or their website shows , so I need to call them for input. Unless someone here cares to elaborate. |
#79
Those are for secondary power.
The power supply I sent you does not have secondary power winding on it. What are you trying to power? The PMDX-126 uses the 115v input power and the Geckos use the primary output voltage from the power supply through PMDX-134 (or PMDX-133) board. If you are going the Smooth Stepper route, You should mount it on the PMDX-126 as a daughter board and take power off of it. This simplifies the wiring and saves space in the box. Also, if you plan to use a spindle in the future, go ahead and mount a PMDX-107 board on the PMDX-126 as shown. This consolidation is just some of the ways as builds progress we continue to refine and simplify builds. |
#80
Thanks Mike.
Ok. One bite down. Now to digest it. Dang glad Tony (my son) is along for the ride. |
#81
Lesson 1.
Dig deeper for solutions. Just because Darren has orange wires doesn't mean I need them. |
#82
Bent parts inventory. This is from a kit i bought from Darren a while back so needed to see if it was all there. Almost. Missing the idler plate m130 332.
And had some extra parts. Extra parts |
#83
no image?
The image is not displaying. It is getting a getting a 403. Basically display is being denied from your google user account.
You may be able to see it, but it is denied to the rest of us. |
#84
OOPS, to late to edit it.
Here they are smaller. |
#85
Looks good! Much better to view!
#86
It's like my birthday every day as I open these packages.
#87
Wish I would have kept it all now.
Oh well. |
#88
What are those pieces in the bottom picture?
#89
proximity sensor mounts/travel stops.
#90
Stop Blocks
The one without the holes is for the Y axis since it usually has some adjusting needed per build. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Back Doing Some Arcade Fun #19 - Smith's Falls, Ontario, Canada | bradyaero | MechMates already cutting | 146 | Tue 27 January 2015 09:41 |
'Clean' Vectors - free project plans for the woodworker | Kobus_Joubert | Golden Resources | 6 | Thu 13 August 2009 06:34 |
It's all Darren's fault!! - Big Falls, Mn | Construction started, but not cutting yet | 0 | Wed 31 December 1969 19:00 |
