Go Back   MechMate CNC Router Forum > Structure & Mechanics > 30. Y-Car
Old Sun 29 September 2013, 20:34
rkd
Just call me: Ryan
BC
Setting all four wheels tight
Hi there. I am setting up my y car right now and I have a problem with only 3 wheels makin solid contact. The 4th is just above the rail. I can push it tight with 1 finger. I have maxed out the adjustments in the slotted hole.
Will the 2 springs be strong enough to bring that 4th wheel down full time? Or should I look into enlarging one of the holes? Or is there a procedure I haven't read yet about twisting the y car straight, similar to the gantry?
Thanks in advance, Ryan
Old Sun 29 September 2013, 22:25
How big is the gap ?
If it is a small gap you could elongate a hole.
Put a spirit level on top of the car to check which hole needs adjusting.
Some of the more experienced builders might have a different approach.
Hang on for some more replies.
Old Sun 29 September 2013, 22:44
rkd
Just call me: Ryan
BC
Thanks. The gap is quite small. A couple of millimetres maybe. I honestly didn't spend a lot of time on it this afternoon. I had a long day in the shop and was pretty tired by the time I got to this point so I just left it. I'll have a fresh look at it tomorrow and see what I can figure out.
Seems to me that I read somewhere on here that Gerald had said that if the offending wheel can be seated by pressing on that corner with one finger, then the motor and idler spring should keep it all tight. I might have that mixed up though, I've read through so many posts lately I can't keep it all straight.
Old Mon 30 September 2013, 09:31
Ryan,
It is true that if the gantry seats with very minimal pressure from your finger, then the hold down springs on the motor plate should be enough.
If not, many options are available to seat the last vee wheel.
Keep us posted.
Old Mon 30 September 2013, 16:52
rkd
Just call me: Ryan
BC
Ok I got it sorted. I was tired and not looking at everything properly. I was fixated on lowering the last wheel and trying to figure out how to get it past it's max adjustment, I didn't even notice that I could just lower the other wheel to bring them both in contact.
Oh well. Teach me for working way past tired.
This gantry and y car roll so smooth for how heavy they are. It was fun for a bit to push it back and forth admiring it.
Old Tue 01 October 2013, 08:00
Glad you got it sorted out.
A fresh set of eyes always prevail after a good rest.
Cheers.
Old Tue 01 October 2013, 13:03
Yeah - we call that the smoke break effect !!!
Old Tue 01 October 2013, 17:57
" It was fun for a bit to push it back and forth admiring it."
I know the feeling.
Like your first pair of roller skates.
Good to hear you got sorted.
Old Fri 04 March 2016, 14:44
Kornerking
Just call me: Pete #127
Big Falls, Mn
Did some of the rolling today myself.
Old Tue 19 December 2017, 18:05
IamDave
Just call me: Davey
Ball Ground, GA
Rolling was good.
Drive tension spring too tight? smreish Troubleshooting 5 Fri 09 March 2018 17:29
Diy Wheels Build your own asif3244 Rails & Rollers 19 Sat 30 June 2012 09:56
Mounting the cables in the cablechain – fairly loose or tight up ? Barman 60. Wiring & Cable Management 15 Tue 26 April 2011 17:54
Aluminium Wheels? ahe_1990 Rails & Rollers 2 Sat 07 August 2010 22:55
Anyone have the MM mounted on wheels ? Stepinwolf General - MM Build 13 Mon 14 December 2009 02:33
