Old Wed 20 March 2013, 03:22
Self Made Control Enclosure
I have a left-over sheet of 17 gauge steel, instead of buying a control enclosure, is it OK to make one or are there rules against such?
Old Wed 20 March 2013, 04:17
Go for it. It has been done.
I would just make wure to create an edge that you can get a good seal on.
You will also want to have a piece of steel or Aluminium to make a back plate for inside the box.
Also 17g is a little thin, but should stiffen up as you build the box. If you have a brake I would role the edge about 1/2 inch to double the thickness of the lip around the box opening. I would also do the same for the lid. Make the lid so it fits over the box like a shoe box. You can hinge or just use screws to keep it closed. Using the shoe box type lid will let you use a piece of hose (Sugical tubing works good for this) to make a seal. You could also use the ruber seal like on the edge of tool boxes.
http://www.realworktrucks.com/servic...trip-trim.html
Old Wed 20 March 2013, 18:59
Thanks for the advise Mike, thought if I had the material...I will try to copy the details of another enclosure I already have but make it the size I need. Hey, do you have an 'interior' control box kit for sale? I've got some of the seal you're talking of.
It's done and made it's first cut! #93 - Clarksville TN USA Darin MechMates already cutting 78 Thu 01 March 2012 22:21
Building an Enclosure Zouave 70. Control Systems 4 Tue 03 January 2012 11:09
20X20x8 Hoffman Enclosure cbboatworks Archives 3 Mon 18 February 2008 11:01
Using a metal enclosure for the electrics vs "plastic" enclosures Tom Caudle 70. Control Systems 3 Wed 10 October 2007 09:03
