Old Fri 05 September 2008, 10:32
No, have not run one yet. I guess I am merely falling back on design principles I use in my day job. 5 watts per unit does seem like it should be ok without thermal interface material. Sorry I just like to err on the side of caution.
Old Fri 05 September 2008, 11:23
I am with Heath on the thermal grease for the Geckos. I am only pulling 3 amps and mine got surprisingly hot until I installed a fan and I was using thermal grease between gecko and heat sink. I will admit it's not much of a heat sink but if memory serves me right it was getting over 130 F before adding the fan. I think it's just a good idea to get all the heat you can out of the box.
Old Fri 26 September 2008, 10:43
Hi Alan thanks for the pictures - these throw a lot on insight to the controller Box.
And even I think the thermal compound is necessary.
RGDS
Irfan
Old Tue 28 October 2008, 11:16
Hi Guys
No, I have not fallen off the earth, but as those who know, setting up ones own's business takes way more time than is available in the day....
Progress has been slow but steady (work interruptions seem to get in the way all the time) below is a shot of one job that has been taking some of my time, its a mixer for mixing polyethelene beads with colour pigment for a big injection moulding company here in Cape Town.
All the parts of the MechMate are now primered and I am now busy applying the top coat, cross supports are done, below are the side frames (without the main beams) with the first side sprayed blue. Picture taken in the metalwork shop at the family business, woodwork shop is through the door on the left of frame)
I hope to have all the spraying done by Thursday, with asembly starting on Friday.
Old Tue 28 October 2008, 11:40
A Blue Bazooka Machine!
Old Tue 28 October 2008, 12:36
That Mechmate blue is spreading into your day job too.
Old Tue 28 October 2008, 15:22
William McGuire
Just call me: Bill
Weiser, Idaho
Nice paint job...
Cool... looks like a prototype for a carnival ride!
Old Tue 28 October 2008, 22:36
Could be used for the LOTTO draw as well.
Nice to see the progress Alan.
Old Tue 28 October 2008, 22:55
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Good workmanship
Old Wed 29 October 2008, 01:52
bakgat vreemdeling!
Old Thu 30 October 2008, 10:33
Assembly is going well, albeit with some minor problems. This being a bolt together, I assembled the complete table, got it squared up and plumb then tacked in the lower cross supports and braces...I did not complete all the welds in place, but finished them after I had taken the whole thing apart - big mistake, everything moved (even areas where i did not weld) and not all of the threaded holes in the frame structure lined up with the holes in the bottom web of the main beams (if the first two bolts were inserted, the other end was off by as much as 15mm ) However there was enough flex in the side frames that I was able to pull the flanges into position with a ratchet load securing strap (the type used on big trucks to secure the load). My Father did not think I would be able to move it that much with only a strap and he was getting ready to start cutting and re-welding to get things to line up, but after some terse words best not repeated he let my try with the strap and was left speechless .
Here is the sequence of assembly:
assy 1.jpg assy 2.jpg assy 3.jpg assy 4.jpg assy 5.jpg assy 6.jpg assy 7.jpg
Old Thu 30 October 2008, 10:39
Table frame bolted, squared and plumb with the support board bolted into place...its starting to look like a MechMate now
Old Thu 30 October 2008, 12:43
About a week or two away from cutting?
Old Thu 30 October 2008, 20:53
gmessler
Just call me: Greg #15
Chicago IL
Looks Great Alan!!
I've had a similar experience with my bolt together.
I did complete most of the welds but touched up a few after I had taken it apart. That was all it took to have the same problem as you. I got most of the bolts in before I ran out of time. I'll have to use your method of ratchet straps for the other holes.
Old Thu 30 October 2008, 20:57
Looking good Alan,
Both the BB and the pictures.
Old Fri 31 October 2008, 00:03
Lex
I have been playing the assembly of my table in my head a couple of times. Handling and bolting each section together. Top channels must be the most akward and heavy to handle. It is a lot better to see it happening in photo sequence. Thanks Alan for showing it like that. Looks good!
Old Fri 31 October 2008, 00:31
Ah beautiful - hope to see it cutting soon!
Old Fri 07 November 2008, 06:33
Assembly done, and wires have been routed ready for connecting up, not long to go now...
I had some cable chain left, so I used it to support the cables running to the spindle/router
Old Fri 07 November 2008, 07:01
Looks Pretty Alan, hope to see it zip zap zoooom !
RGDS
IRfan
Old Fri 07 November 2008, 07:23
Alan,
In the first picture it looks as if your Mechmate had an accident on the floor. Bad Mechmate.
Old Fri 07 November 2008, 07:50
When are you inviting me over for the wetting ceremony?
Old Fri 07 November 2008, 07:58
Looks like it was done already
Old Fri 07 November 2008, 08:00
That was Alan . . . . when he walked into the end of the x-rail . . .
Old Fri 07 November 2008, 09:09
gmessler
Chicago IL
Looks Great Alan!!
Nice idea for the z cable management.
Old Fri 07 November 2008, 09:17
gmessler
Chicago IL
Maybe he was just excited to see how far along his machine is.
Old Fri 07 November 2008, 12:22
OH OH,
Somehow I think I will be blamed for all of this.
Old Fri 07 November 2008, 14:40
You Guys are too sharp, thanks for that Heath , as can be seen by all the plastic sheeting in the background, the roof in this section of the factory is less than watertight so the machine gets covered at night and when it rains. (another chore to tackle before serious production starts)
Note also the black rails as suggested by J.R., thanks for the idea, they look cool.
Old Fri 07 November 2008, 16:12
I know Gerald doesn't like background clutter in shops because it eats up bandwidth but I sure like looking at the stuff people have in their shops and drooling over the raw materials in racks. You've got some great stuff there Alan. Sure wish I could come over and poke around.
Oh yeah and your machine is first class just like your photography skills.
Old Fri 07 November 2008, 19:59
Ok, everybody post pics of the side of your workshop that you don`t want to show
So close but o so far, Nice Alan get it cutting!
Old Sat 08 November 2008, 22:48
Looking good Alan. That spot on the floor I would have called BLOOD, SWEAT and TEARS
