Thread Tools |
Milwaukee 5625 failure: electronic speed control?
I was running two cut files on my MM this afternoon. The first one ran fine, and completed in about 20 minutes. I swapped a new workpiece onto the table, loaded the new gcode, hit start, and... the MM started running, but the router didn't power up
![]() I tested various things with the router on the Z slide, including powering it directly from an extension cord, with no success. Resigned to sending it in for warranty repair, I removed it from the MM. As a last-ditch effort, I tried moving the electronic speed control knob through its FULL range of motion. When I got to the highest setting (7) the router powered on! Has anyone else encountered this before? Could this be caused by dust or dirt in the knob assembly? Hmm... ![]() |
Michael,
I have had to replace the electronic speed controller. I suspect this is a weak part. It is sealed so I don't thing it has any thing to do with the dust. I would suggest that you buy an additional set of brushes and a Tach. These are the parts that I have also replaced. Fortunately these parts are also less expensive. Are you replacing your collet and nut regularly and are you cleaning them? It makes a difference in the quality of cut and helps the life of these parts. I have been running the same router since 2008 but I have a back up rounter in case I have a job and can't get the part I need. Hope that helps. |
If its under warranty send it and they will change the speed control. Depending on the construction of speed control the full speed bypasses it and gives full voltage to the motor, so if its faulty then it would behave like yours do.
Had problem also. Repair shop said it was the armature. Fixed for free but we bought another for backup.
Thread Tools | |
Collets for the milwaukee 5625 router | dragonfinder1 | 50. Toolheads | 5 | Thu 06 May 2010 08:47 |
Milwaukee 5625, how fast do you turn it. | dragonfinder1 | 50. Toolheads | 5 | Tue 16 March 2010 10:33 |
Router Speed/RPM Control | Travish | 70. Control Systems | 5 | Sun 18 October 2009 08:49 |
Router bracket for Milwaukee 5625-20 | Roadkill_321 | Dxf Library | 0 | Sat 03 May 2008 20:13 |
Router speed control | coogrrr | 50. Toolheads | 18 | Sat 23 February 2008 03:05 |
