Old Tue 17 July 2012, 21:56
sierra347
Just call me: Armando #110
Montgomery, IL
I have the 72 count larger pulleys so an 18 or a 24 would work.
Armando
Old Sat 21 July 2012, 13:01
JasonC
Just call me: Jason
Soldotna,AK
Armando your 14mm ID, 18t pulleys are done. PM me a address
Jason
Old Tue 24 July 2012, 06:29
JasonC
Just call me: Jason
Soldotna,AK
Armamdo you may need different belts if you had a 24t setup sent to you.
Jason
Old Tue 24 July 2012, 07:07
JasonC
Just call me: Jason
Soldotna,AK
Looks like the difference between a 24t x 72t(100 teeth and 4.962",3:1) and a 18t x 72t(98 teeth 5.0019",4:1) is 2 teeth and .038 of a inch, to be 5 inches part.
Jason
Old Tue 24 July 2012, 20:47
sierra347
Montgomery, IL
The setup I had originally was the 18x72 (4:1) so I should be ok.
Armando
Old Sat 28 July 2012, 13:29
sierra347
Montgomery, IL
Jason,
I received the pulleys you machined for me and are way way better than the the ones I screwed up on the drill press. I can now move forward with the transmissions. Thanks alot for your help.
Armando
Old Sat 28 July 2012, 19:45
JasonC
Just call me: Jason
Soldotna,AK
No problem. I just speed reamed them on the lathe. I have time issues. If you need a high tolerance let me know.
Jason
pinion gearing and difference in sizes Gabriel Rails & Rollers 4 Wed 18 May 2011 14:19
Spur Gears where I can get them besides mcmaster? kanankeban Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 8 Tue 29 June 2010 17:34
Spur Gear decision shelbygt500buddy Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Wed 14 April 2010 05:46
Cable amp wire sizes Gerald_D Golden Resources 3 Sun 14 December 2008 23:17
Steel sizes Gerald_D Golden Resources 2 Fri 05 December 2008 12:25
