Old Wed 28 December 2011, 10:11
kalimero
Just call me: kalimero
buffalo
Gecko 202 resistor ???
Hi,
I have ncpod board gecko202 drivers , power supply 24v/6A and motors;
Model # 24H290-35-8B
Bipolar Serial specs
- 2.5 A/phase
- 2.4 ohms/phase resistance
- 8.4 mH/phase inductance
Bipolar Parallel specs
- 5.0 A/phase
- 0.6 ohms/phase resistance
- 2.1 mH/phase inductance
I like to use bipolar parallel setting but I don't know what resistor I need to buy.
Thanks for any help.
Old Wed 28 December 2011, 12:53
A 100 K to 120K 1/4 Watt resistor will work.
47 X 5 Amps / (7 Amps - 5 Amps) = about 120K
Old Wed 28 December 2011, 14:41
kalimero
buffalo
Old Wed 28 December 2011, 19:48
kalimero
buffalo
What is reason that motors are very hot and they not working at all?
Old Thu 29 December 2011, 09:07
Stepper motors can become very hot (up to 80-degrees C or 176-degrees F). The G202 has an Option Jumper Block, where you can jumper the drive to go into auto current reduction 1-second after the motor stops. Auto current reduction reduces the current being drawn by the motor to 33% of maximum. It also reduces heat in the drive and in the motor substantially.
Verify that you are using a heat sink capable of keeping the G202's case temperature below 70-degrees C (158-degrees F).
Before I can help you with the no-motion problem, I need to know which break-out-board you're using and what software (Mach 3 or other) you're using.
The common terminal (pin 10) needs to be connected to +5VDC. Each time you momentarily touch the step terminal (pin 9) to ground, the motor should make one step. It takes 2,000 steps for one revolution, but you can usually feel the shaft turning and you can usually hear the motor making a step.
Old Thu 29 December 2011, 09:56
kalimero
buffalo
I have ncpod board and mach3. I connect all wire in order but my problem is:
I don't know how to setup motors in mach3.
Gecko temparature is OK.
If any one can help me to setup , if I need to pay I will pay for that.
Old Thu 29 December 2011, 19:32
The documentation for the NcPod is very limited. Without using a meter or an oscilloscope to verify the polarity of the signals, I would hesitate to make any suggestions. The documentation shows +5 and -5. Normally there would be +5VDC and Ground. I'm assuming that there is no -5, but without checking I can't be sure.
The G202 requires that common be tied to +5VDC and that the actual step is activated by pulling step signal to Ground for a very brief period.
Mach 3 can be configured to supply either a rising or a falling signal. Until the NcPod is correctly connected to the G202 modules and until Mach 3 is properly configured, nothing will work as expected.
Old Thu 29 December 2011, 19:40
kalimero
buffalo
I just install everthing and look that motors turning but very slow and they have very high tone when they just stay with power on. Mash3 manuel is big and I already read twice, but still don't undenstand even 20%.
Thanks for your help.
Old Fri 30 December 2011, 09:31
This would be a great opportunity for someone who uses Mach 3 regularly to help Kalimero understand motor tuning and steps per inch. (I've got to rebuild my Windows XP machine, so I don't have access to Mach 3 at the moment.)
How to calculate resistor needed for gecko drives Richards 701. Motor Drives 8 Wed 15 May 2013 08:52
New Gecko Faulting - RED LED tnarch 701. Motor Drives 7 Thu 18 October 2012 23:56
Servos for gecko drives. agfmaquinas 701. Motor Drives 5 Thu 24 March 2011 15:45
Alternatives to Gecko Drive? liaoh75 70. Control Systems 4 Sun 09 May 2010 11:03
gecko 210 WOODCHUCKMAN 701. Motor Drives 3 Sat 21 February 2009 13:13
