Old Wed 21 December 2011, 15:27
kanankeban
Just call me: Hector #89
Monterrey
Mexico
Help with PK296A2A-SG7.2 and geckos 203v
Im confused, which color of cables are used with the geckos, i have black to A, green to A-, red to B and blue to B- is this configuration correct?
Old Thu 22 December 2011, 08:21
You've wired the motor in its bipolar serial configuration. You will get better performance if you wire the motor half-coil which is:
Black to A
Yellow to A-
Red to B
White to B-
Half-coil gives you 70% of the torque of a motor wired bipolar serial, but it gives much better speed. Because of the limitations of the gearbox, wiring the motor half-coil will still give the motors all the torque that the gearbox can handle. So, wiring the motor half-coil gives you all the advantages and none of the disadvantages.
Gecko 203v - Blown fuse beckj 701. Motor Drives 5 Sun 24 December 2017 09:05
PMDX-122 & Geckos 203V Diagram ??? kanankeban 701. Motor Drives 1 Wed 07 October 2009 23:00
"Gecko 540" vs. "PMDX-122 & Geckos 203V" kanankeban 701. Motor Drives 10 Thu 19 February 2009 08:19
Geckos on sale!!!! J.R. Hatcher 701. Motor Drives 12 Fri 14 November 2008 08:09
Geckos on Ebay 275 for 3! stefanv Archives 0 Fri 08 February 2008 09:59
