Old Mon 10 October 2011, 08:39
JasonC
Just call me: Jason
Soldotna,AK
This is just kitchen table so far. Bipolar parallel with a 270K resistor just to get things moving. The motors didnt evan get warm at all so when i ran a 25 min g-code test run. There was a slight temp change but not more than if your hand was in the shade and moved into direct sun light on a 65 degree day I would say. So Ill will ramp it up to 330K then to 470K when the table is built...which is next. I had to ditch the On/Off push button, I rewired that put 4 times(per time plans) and it fired the On switch side each time.???.
Jas
Old Mon 10 October 2011, 08:59
JasonC
Just call me: Jason
Soldotna,AK
If it possible to edit the #46 entry on this build thread it is wired incorrectly! My fault. The A1/A2 coil are on the top(left side of contactor in picture) not the side.
Jason
Old Mon 10 October 2011, 11:56
Jason, just post the correct info and someone can fix the other post for you.
Old Sun 23 October 2011, 15:23
JasonC
Just call me: Jason
Soldotna,AK
Table is standing. Working on the rail drilling and placement.
Is the only thing holding the rack on the X rail is 3M tape and the 2 end bolts?
Jas
Old Sun 23 October 2011, 15:32
JasonC
Just call me: Jason
Soldotna,AK
The other question is the height of the X rail with a V cap. Im using steel angle 2x2.5. Can I keep the height of 2 inches to place the V cap on?, avoiding half to cut a 10' long 1 inch peice on the 2" height off? Im concerned about the distance between the Top of the V cap and the where the rack and pinion meet if I keep the 2" height.?.
Jas
Old Sun 23 October 2011, 17:55
timberlinemd
Just call me: Steve #66
Arizona
Jas
Yes, and it is plenty.
Old Sun 23 October 2011, 17:58
timberlinemd
Arizona
Jas
You must keep the height according to the plans if you want the system to work, otherwise you will have to adjust numerous other parts to accept the higher rail height.
Old Sun 23 October 2011, 18:01
Red_boards
Just call me: Red #91
Melbourne
Jas
I think you will run into problems with the motor/pinion union (i.e. the motor brackets won't let the motor pivot low enough to reach under a 2"+ high rail).
The rail cutting to height is not hard. Just look at the various jigs people have built for this. And use thin cutting disks.
Old Thu 03 November 2011, 09:01
JasonC
Just call me: Jason
Soldotna,AK
Table is assembled, X rail for Vcap cut to proper height. I will get some pics rolling soon.
Jas
Old Tue 29 October 2013, 17:52
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Rail Caps
I bought rail Caps and now wish I hadn't. The grinding isn't all that bad and you replace that task with drilling and tapping holes. I would rather grind. Want to buy some rails? Don't use 1/4-20 screws they are to big.
Old Tue 29 October 2013, 17:56
Jas
My machine has well over 200 hrs. with only 3M tape bought at Autozone holding it on. No bolts, no welds. Just tape.
Old Tue 29 October 2013, 18:30
Mrayhursh
Riverview, Florida
Duct Tape
What no Duct Tape
Anyone can help for moter turning setup jek 70. Control Systems 3 Sat 08 October 2011 21:52
Motors turning! (under EMC) - Perth, Western Australia shaper Construction started, but not cutting yet 23 Sun 29 November 2009 17:21
Newbie has motors turning already - Alpharetta GA reza forushani Construction started, but not cutting yet 33 Fri 25 May 2007 21:46
