Old Wed 10 August 2011, 21:07
PEU
Just call me: Pablo
Buenos Aires
Another photo, this time my wife:
http://www.youtube.com/watch?v=op_tHMJI7FY
Pablo
Old Wed 10 August 2011, 22:59
Hey Pablo, you could have used a nicer sheet of wood for such a lovely lady
Looking good, mind sharing your sizes, settings and bits used. I tried one the past weekend and it was not THIS good.
Old Thu 11 August 2011, 05:45
PEU
Just call me: Pablo
Buenos Aires
LOL yeah, I used an old piece of scrap melamine, I will buy mdf coated with melamine that is used for drawer bottoms and cabinet back panels, its only 5mm thick and very cheap because melamine is on one side only, but in the meantime you use what you have at hand
I used white/black, a 45deg V bit, min diameter 0.4mm and max diameter 2mm, spacing also 2mm, Z needs to be very accurate using these settings because when the hole is 2mm, and there are many next to each other, there is almost no material left in the surface, and you need it for contrast.
I did not show the other side of the board for a reason I set it up a little deeper and in the hair area the holes ate all the melamine.
Old Thu 11 August 2011, 06:10
OK so basically it is one of those ENGRAVING bits. I used my 90 deg 12mm bit.... I see some contrast, but not good enough.
What is the overall size of the piece ?
Did you wipe in BLACK paint to fill the holes for more contrast or is that the wood colour we see. (brownish)
Old Thu 11 August 2011, 06:17
olz
Just call me: Bubolz
Pelotas/RS
Brazil
Salve!
Originally Posted by Metalfusion View Post
Version 2.0 is up!
Great job Tomi!
It would be possible in future implement halftones with straight lines?
Abs.
Paulo Marcos G. Bubolz
Design libertário - Arquivos Gratuitos para Fresa/Corte
Old Thu 11 August 2011, 06:29
PEU
Just call me: Pablo
Buenos Aires
I used PCB engraving bit, because the bigger one I had that came in a router bits set wasn't pointy enough. Im looking for a local source of this type of engraving bit http://cgi.ebay.com/1-4-Router-CNC-E...item1e63a3e904 it looks pointy as needed for the job.
The board size is 210x210mm. Yes, after machining I used a very liquid mixture of black tint to darken the holes and then wipe the excess with a cloth.
Old Thu 11 August 2011, 07:42
Metalfusion
Just call me: Tomi
Tampere
Finland
Originally Posted by olz View Post
Salve!
Please, do some research before asking. Version 2.0 also does straight lines.
And for everybody else too: If you haven't noticed, there is a user guide in the readme file that comes with the software. It briefly covers every setting and feature that the program has.
No offense
Old Thu 11 August 2011, 12:14
PEU
Just call me: Pablo
Buenos Aires
Non taken maybe a little question mark that links to the help file would save you answer that question again.
Looking at the source code I found this comment that made me happy:
'the size limits from dxf export tab also affect the gcode generation
I just tried it and indeed a lot of holes are not created thus saving a lot of time.
In my wife carving it would go from 10081 to 6312 dots, about 40% less machining time
Cool
Old Sun 04 September 2011, 11:36
Metalfusion
Just call me: Tomi
Tampere
Finland
Version 2.1 is up!
The changes from version 2.0 mainly consist of some significant bug/glitch fixes. It is highly recommended to update. The dot halftone toolpath is now optimised, it goes back and forth instead of doing long rapids.
Changelog entry:
Code:
4.9.2011 V 2.1
Polishing, some important fixes.
IMPROVEMENTS / FIXES:
	-Fixed multiple problems with path width calculation algorithm.
		-More accurate results with large line spacing values.
		-Much less noise / artefacts with small resolution source images.
		-Fixed path endpoint sizing problems.
		-Improved performance with large image files.
	-Optimised toolpath generation ( shorter rapids ) for dot halftones.
	-Added "optimiserapids" option to save file format. When set to zero, all path filler lines will be run in the same direction.
	-Fixed a nasty memory leak where none of the memory allocated for the path data was freed.
		-It was caused by the Blitzmax's carbage collector's inability to handle circular references.
	-Now works with huge amounts of filler dots ( tested with over 5 Million dots ).
		-Also tested to work with up to 100 Megapixel source images.
	-Changed the default settings to give a better first impression.
Download here:
http://www.students.tut.fi/~syvajar3...alftone_21.zip
Old Mon 05 September 2011, 05:28
Thousand Thanks! This is wonderful!
Old Mon 05 September 2011, 11:25
PEU
Just call me: Pablo
Buenos Aires
Thanks Tomi, it gets better and better every release. Thanks!!
Old Thu 08 September 2011, 07:23
Pixelated
Just call me: Tom
Plymouth
I thought I'd just add that you can create these sorts of images in Illustrator with the Object Raster script from Scriptographer.org. e.g.
Old Sun 30 October 2011, 07:59
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
Kind of a Half-Tone thing. I wonder how they do this?
http://www.interlam-design.com/Mirage_ProductList.cfm
Old Sun 30 October 2011, 11:25
Jason Marsha
Just call me: Jason
B'Town
Barbados
Perfect for cnc.
Take a peep at their wall panels which they call art diffusion
http://www.interlam-design.com/Art_Product_Search.cfm
Its an impressive gallery of designs of which many can be done with a cnc machine.
Old Mon 31 October 2011, 05:56
PEU
Just call me: Pablo
Buenos Aires
Check: http://jasondorie.com/page_cnc.html (Reactor Entry) the process take time (more resolution, more time) but the result is the same.
It works like a worm eating the photo, at worm speeds
Old Mon 31 October 2011, 13:00
JasonDorie
Just call me: Jason
Petaluma, CA
I have a version of the Reactor software written to use your graphics card for processing, and it is easily 10x faster, more if you have a good card. So far I've been restricting that version to commercial users, but I may change that.
I also have a halftone program with similar capabilities to Tomi's, and a realtime preview.
Jason
Old Mon 31 October 2011, 18:01
PEU
Just call me: Pablo
Buenos Aires
If you ever release it let us know Jason, in the meantime is fun to see the worms eat the whole picture
Thanks for the free software!!
Old Mon 31 October 2011, 21:17
I like the "worms" much more than the other patterns because they give a better definition:
Old Mon 31 October 2011, 22:31
lunaj76
Cool Thanks!
Old Mon 31 October 2011, 22:35
Thanks for the great software!
Old Fri 04 November 2011, 19:10
Jason Marsha
Just call me: Jason
B'Town
Barbados
Oops I crashed VCarve with the Reactor output file. I guess the pic was too big.
Old Fri 04 November 2011, 19:54
JasonDorie
Just call me: Jason
Petaluma, CA
I've done that a couple times now. I usually do the joining and the carving paths in sections now and keep an eye on the memory usage as I go. 1.7Gb is the point it goes boom.
Old Sun 13 November 2011, 06:38
Jason Marsha
Just call me: Jason
B'Town
Barbados
Ok that's good. I thought I had to install some more memory.
Old Fri 27 January 2012, 02:37
rischoof
Just call me: Rik #92
Goirle
load a picture in reactor 1.2
Does somebody know how I can load a picture in reactor 1.2?
When I open reactor 1.2 I don't know how to copy in or load a picture.
must it be a black and white picture?
Old Fri 27 January 2012, 13:25
JasonDorie
Just call me: Jason
Petaluma, CA
Just drag & drop it from your Explorer, and no, it doesn't have to be black & white.
Old Tue 04 September 2012, 16:14
PEU
Just call me: Pablo
Buenos Aires
Found another program that uses a different algorithm:
http://www.evilmadscientist.com/2012...in-processing/
Freeware!
Pablo
Ghost in the machine ?... Router creating its own G code Blue eleven Troubleshooting 22 Mon 02 August 2010 22:12
Mr Lasercut&bend has his own machine drawing pictures! #42 - Birmingham, AL jbmclain MechMates already cutting 25 Mon 14 December 2009 09:27
Creating a "manual" to describe the MechMate build process Gerald D Archives 5 Thu 05 June 2008 17:09
Why can I sometimes not see all the pictures? Mike Nash About this Forum 5 Sun 27 January 2008 09:39
