Old Thu 23 June 2011, 10:19
Privacy screens for Casino Restuarant
Another job I just got installed today at the local Casino. The restuarant has a low wall around one portion of its seating area and the management was understandably not happy that visitors to the casino used the wall as impromptu seating while waiting or resting from throwing their money away. The engineering department asked me to come up with a neat stylish solution using a pattern from an existing wall decoration at the restuarant.
There are ten plywood panels in total secured by steel posts bolted to the top of the wall, these steel posts are covered by hollow plywood columns which are secured to the steel inside. Sanding on this job was a nightmare with all those little holes but the end result looks very good - client is extremely happy so that makes me happy
View down the left side, two sections of panels on this side.
View down the right side with young Kevin installing the last few cap screws to secure the wooden columns to the steel posts.
Detail of a single panel with the original laser cut steel panel in the background, the pattern was copied from this for the ply panels.
Detail of the steel support post with a ply column on the left.
Old Thu 23 June 2011, 10:52
Very impressive job! Bravo!
Old Thu 23 June 2011, 11:37
Very very nice. Well done
I better come and check it out next week when I am in CPT
Old Thu 23 June 2011, 12:09
timberlinemd
Just call me: Steve #66
Arizona
Were you able to remove all of the red chalk on the stone left by the chalk line?
Old Thu 23 June 2011, 21:44
Leko
Just call me: Leko
Kaukapakapa
New Zealand
That looks great! Nice solution for internal structure, and for minimizing exposed fasteners. Looks like that Hilti got a workout!
Old Fri 24 June 2011, 07:52
Looking good Alan,if Kobus visit teach him how to use a broom.
Old Fri 24 June 2011, 07:58
Passop vir jou ...jy sal kom skoonmaak hier
Old Fri 24 June 2011, 10:36
Thanks guys, Steve - what looks like stone is actually cast concrete with a plaster finish so the chalk line wiped off easily with a wet rag. Leko - the Hilti didnt even break a sweat, great machine.
Hennie, you've seen my workshop. I dont even own a broom
Old Fri 24 June 2011, 12:21
Alan,
Question - did you have another sleeve or dimensional cap on the inside of the wood vanity column to keep it centered or did the panel do that for you?
Like Matthew (Leko) mentioned - just the elegant solutions we look for with our interior installs daily.
Nice work.
Old Fri 24 June 2011, 14:50
The panels are held captive by two rods welded to the face(s) of the rectangular tubing, that locates them front to back. The slot in the wooden column passes over the panel and is held in place left to right by the top and bottom cap of the panels (you can see the end of the bottom cap and foot in the last photo) The slot and top and bottom caps ensure that the wooden column can't move in any direction.
Old Sun 27 November 2011, 06:11
MariusL
Just call me: Marius #22
Centurion
Alan
What did you use to finish the job with? (Stain / varnish)
Old Sun 27 November 2011, 06:18
Penetrating stain (Chemspec - Mahogany) wiped on, then two coats of Catasatin AC Lacquer (tinted with a bit of the stain to cover any sand throughs) also from Chemspec.
Old Sun 27 November 2011, 06:34
MariusL
Centurion
Thanks Alan, by the way, those screens look very classy.
