Old Thu 27 January 2011, 04:43
Quadro
Just call me: Anthony #77
South Australia
I found grinding the rails is alot easier when i used one of those sandpaper/grinding disc. It can be ground in less than 1/4 of the time and less cost, 1.5 discs for 3.6m worth of grinding. The normal grinding discs kept on glazing up even the grinding is done near the edge of the disc.
Old Thu 27 January 2011, 08:14
That is a great note that I don't think get's shared enough. Start with a 36 or 50 grit and finish with a 80 or 120 grit to polish.
For the new readers, make certain that you have a VERY stiff backer to the sanding disk unit. Some of the backing plates on the disks can be to flexible and not give repeated grinding results. I personally put the sanding disk ON TOP of an actual grinding disk as a FIRM back.
Thanks for sharing.
Old Thu 27 January 2011, 18:59
Quadro
South Australia
I set the skate so that it was grinding in the middle of the disc with the rubber backing where it is a lot stiffer, as can be seen in the photo with the grey mark. It is not the opitmum spot for grinding (cutting tip speed, what ever it is called it grinding terms?).
I think using a grinding disc instead of the rubber backing is a very good idea and would be far better.
I timed my self and it took 1/2 an hour to grind 3.6m and 1/2 an hour to cut with 1mm blade. It has gone from a painfull process to a painless process.
Old Fri 28 January 2011, 04:08
Allow me to add to your caution SEAN.
Cheep grinders ( like the one I used back then) have some “flex” due to cheep bearing or bushing to chaft tolerance making the “stiff” disc still “wobble” out of axis.
I remember to remedy this had to take VERY very light passes in order to achieve a respectable flatness ….and goes without saying I had to replace that “cheep” darn oem bearing after only one rail ( see this)!
Buy good tools once rather than a "cheep" making it hard on you !
Robert
Old Sat 29 January 2011, 04:41
Anthony
I'm with Sean, the rubber backing pad will give a second class result in comparison to using a grinding disk as a backer.
I have really tried to get this method out there for all to see after reading it on the forum myself.
I asked Redboards to run some comparison tests before he did his rails and he is a convert of the technique.
As Sean says, run up the grits and by the time you get to 120 Grit, it polishes the rails.
Good luck with your build.
Old Sat 29 January 2011, 19:31
Quadro
South Australia
I don't disagree with you or Sean.
If I was to to it again I would do as you have explained. When I had read Sean's post I had alredy completed the grinding.
The local Hardware Store only had 36 and 60 grit, so did the main cutting with the 36 and finished with 60. The surface still had machine marks so I draw filed with a 12" finishing file.
If some can tell me a good reason(s) why I must have 'polished' rails (apart from me being able to see myself combing my hair) I will do it, I think it is acceptable.
Old Sat 29 January 2011, 19:41
Hi Anthony
The accuracy of the rails are the only consideration, everything else is really only cosmetic. Small scratches will not interfere with the operation of the machine.
The section of rail you have shown looks to be the goods - well done.
Old Sun 30 January 2011, 01:02
Not just for combing your hair, Polishing the rail is also a great way to kill time.
Old Sun 30 January 2011, 05:13
I need links to where others have talked about sanding pads instead of sanding disks.
I also would like to see the link where that skate bottom is discussed.
I will add content to this thread so we have this pointed out to new builders.
Old Sun 30 January 2011, 05:26
Mike - My experiences start at Post 186 in my thread.
Old Sun 30 January 2011, 05:57
Mike,
It all started kinda here:
http://www.mechmate.com/forums/showt...51&postcount=1
Then prototyped here:
http://www.mechmate.com/forums/showthread.php?t=479
Then more protype here:
http://www.mechmate.com/forums/showthread.php?t=19
And final built protype that ended up being the production version in the drawing package before the bolt cutouts were added for the roller option on this skate.
http://www.mechmate.com/forums/showt...?t=460&page=10
Old Sun 30 January 2011, 18:28
Regnar
Just call me: Russell #69
Mobile, Alabama
Mike my experience is here
http://mechmate.com/forums/showthrea...&postcount=128
and here
http://mechmate.com/forums/showthrea...&postcount=133
I highly recommend the Sanding disk over the grinding disk. Removal rate was incredible. I also recommend a face mask with eye protection as the sparks really fly everywhere.
Construction has started - Melbourne, AU Besser Construction started, but not cutting yet 63 Thu 10 February 2011 00:27
Construction started - Laibach, Slovenia macky Construction started, but not cutting yet 8 Fri 23 April 2010 08:12
Construction started - Greece foinikas Construction started, but not cutting yet 20 Thu 31 December 2009 10:13
A very simple sanding device gixi Miscellaneous / General / Whatever / Catchall 2 Mon 29 June 2009 07:14
Stymied on rail grinding - until the Pferd disks were found skypoke Rails & Rollers 3 Sun 09 March 2008 11:46
