Old Mon 17 January 2011, 15:05
skippy
Just call me: Paul #72
Hitachi SJ200 and ModBus Control Problems
As you may already know Tony and I are trying our hands with a Hitachi SJ200 VFD. We have the unit working with no problems with the keypad, start stop the spindle and any speed set with the pot.
Now if we connect it by ModBus with in Mach3 Config ModBus the <Test ModBus> I'm able to write and read both Coils and Holding Registers with no problems except when issue the coil 0001h Run command and the 0002h Direction Command the VFD goes into Alarm mode and needs to be reset to clear the Alarm code.
The only Settings change are A001 and A002 to 03 so that it's now using ModBus and the 485 switch has been selected.
SJ200 VFD Settings
A001 = 03 Frequency Source Setting
A002 = 03 Run Command Source Setting
A003 = 400 Base Frequency Setting
A004 = 400 Maximum Frequency Setting
A044 = 00 V/f Characteristic curve Selection
A082 = 220 AVR Voltage Select
C071 = 06 Communication Speed Selection
C072 = 1 Node Allocation
C074 = 0 Communication Parity Selection
C075 = 1 Communication Stop Bit Selection
C076 = 02 Communication Error Selection
C078 = 50 Communication Wait Time
Any help would be much appreciated
Paul (Skippy)
Forward Message
Old Tue 18 January 2011, 06:05
Greolt
Just call me: Greg
Victoria
Paul
One thing I have learned after much head scratching,
Run is 0000h and direction is 0001h.
0002h is the register to send an alarm command.
I know...I know......that is not how the Hitachi manual reads.
As soon as I stopped sending a 1 to 0002h, the VFD stopped going into alarm condition.
In fact the only coil register I send, is a 1 to 0000h.
The default direction (CW) is all I need anyway. So no need to command that. (0001h)
Old Wed 19 January 2011, 02:11
Have you tried a 68 ohm resistor?
Sorry Skippy just could not help myself !!
Old Wed 19 January 2011, 04:03
AuS MaDDoG
Just call me: Tony #71
Brisbane
Lol !! now now boys
Tony.
Problems registering with this website . . . . Gerald D About this Forum 15 Wed 04 April 2012 06:44
K2 Hitachi Router Mount Modification using SteelMax Saw dmoore 50. Toolheads 5 Thu 22 May 2008 16:54
Anyone else having forum access problems? Gerald D Archives 18 Wed 22 August 2007 12:43
Small problems Admin Test Area for this forum 14 Sat 02 June 2007 23:41
Big Problems Admin Test Area for this forum 8 Tue 22 May 2007 08:38
