Old Thu 02 December 2010, 10:12
silverdog
Just call me: Sergio #70
Rome
Italy
Bits ... the selection of bits, truth, myth, etc.
Well, I start this thread not to give advice, I'm not the right one, but .... having finished the MechMate, the next problem is ... make it works. To do so you need to lear the software and you need Bits to make practice.
So after searching on the forum for info and "google-ing" around, I contacted some producer here I report and share my info.
On the forum I have learned that solid carbide is the right choise, and better avoid HSS (source: Gerard)
It was difficult to find solid carbide for woods, but many reported that metal bits are ok ....
Three out of Three producer/distributor of solid carbide bits told me the same things: their bits are not suitable for woods, I insisted that I know it's ok to use metal bits, and those are the answers:
1) www.europatool.co.uk told me: "Our products are not suitable for wood, they are for metal cutting." after insisting they sent me their catalog.
2)HITACHI TOOL ENGINEERING EUROPE GMBH told me (after my insistence): Actual we don’t have any mills which can be used in wood.
For wood you need sharp uncoated end mills. Our end mills are all coated.
That’s the reason.
3) www.dhfitalia.it : Our mills are only for metal, their geometry is not suitable for woods.
Serching in the forum I saw tha Onsrud ave a choice of mills suitable for woods, but not that easy to find in Italy
then our friend "renraku" (Italian from Rome) told me he has a lot of CMT mills for wood that he bought locally.
http://www.cmtutensili.com/viewdoc.asp?pars2=1~18~1~2~2
It seems they have a good choice, there is a shop in rome where they sell only woodworking stuff and they have stock of them.
I bought some CMT I will report my inexperienced impressions.
It would be nice if others here corect me,and/or give their contribution to general knowledge. For example: can somebody tell the difference between straight, spiral, compression, upcut, downcut ..... ecc. ?
thanks
Sergio
Old Thu 02 December 2010, 10:42
check out this site.
www.woodworkerswholesale.com
Thermwood is a very expensive device, but this supplies site looks like it has a lot of items focused towards us MMers.
Old Thu 02 December 2010, 11:03
Sergio, go and try the cheapest, 2-flute, up-spiral, solid carbide bit that you can find. Do not look at catologues. Tell the salesman that you are cutting aluminium if he really wants to know the material. He should find you something from under his counter with no name on it, that he imports from Asia. This type of cutter has been the most economical for us on cutting "wood" (MDF).
Old Thu 02 December 2010, 11:07
silverdog
Rome
Italy
Thanks Mike very interessing site I have to study a bit !
Here there are many answer on the questions I posed in post 1 (upcut, downcut ecc) page 89 of the catalog.
http://www.cmtutensili.com/viewdoc.a...2=28~178~5~2~3
thanks Gerard, on that multilanguage catalog with pictures even a "dummy" like me can understand (translation is important: upcut downcut ecc are difficult to explain to an italian salesmen, at least it's good to know better than him what he is trying to sell you :-) )
Old Sat 04 December 2010, 09:08
liaoh75
Just call me: David
Taibao
Taiwan
Sergio,
I've went down the exact same road you are traveling on now. I ended up using cheap MM straight bits that are about $2 dollars a piece and they have held up well with MDF. I use vac hold down so I avoid up-cut bits if I can. I've snapped a number of MM bits but the MM two flute straight bits work well for me. Good luck!
Gerald, correct me if I'm wrong but in my neck of the woods, bits designed specifically for aluminum tend to be more expensive than the average two flute carbide end mill. To my understanding, bits designed for aluminum have a very aggressive chip removal geometry. I use them quite extensively for cutting acrylic with excellent finishing results. I've never tried them with wood as they are a little expensive but I'll give a well used one a try.
Old Sat 04 December 2010, 09:22
Dave, I just got quotes from my friendly local hardware stores. Carbite bits for AL are expensive... but those Cr coated are really palatable... will this be good enuf for acrylic?
Old Sat 04 December 2010, 12:51
David & Ken, the last time I personally looked for bits (my son does that now) the local companies supplying cheap imported Asian bits did not have special Al cutting bits, so their cheapest bit had to do the job. And it did the job fairly well.
Old Sat 04 December 2010, 20:58
My kind of approach
Old Sat 04 December 2010, 22:32
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
We have found single cutter straight bits to offer the best longevity.
http://www.grizzly.com/products/Sing...-4-Dia-/C1465Z
We've tried upcut 2-flute solid carbide from bosch and a couple others whose names escape me at the moment. We've also tried 2-flute straight cutters. The single flute bit outperforms.
In 1088 marine ply, we run about 200ipm peak speed @ 20,000 rpm @.25" DOC.
If we had a spindle, or really huge ipm speeds we'd reconsider 2-flute designs.
Speeds, Feeds, Materials and Bits smreish Cutting various materials - bit selection, feeds, speeds 65 Sun 11 March 2012 08:01
40% router bits for two days even Onsurd chris saintdenis The Market Place 0 Thu 30 September 2010 10:38
Cutting bits for routers / spindles fabrica Cutting various materials - bit selection, feeds, speeds 70 Sun 27 June 2010 09:20
Straight-flute bits and safety lumberjack_jeff Cutting various materials - bit selection, feeds, speeds 8 Sat 27 March 2010 13:20
Up Spiral Bits PEU Cutting various materials - bit selection, feeds, speeds 24 Sat 27 March 2010 11:04
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
