Old Tue 18 May 2010, 11:28
F2DVasek
Just call me: Vasek
Perm
Russia
Need Help with Power Supply Selection
Good afternoon!
I apologise that has got into another's theme!
At me a question:
It is required to me запитать 5 motors:
SY85STH156-6204A - 3 pieces (a current of 6,2 amperes)
SY85STH118-6004A - 2 pieces (a current of 6 amperes)
The driver to 80 volt.
Prompt please what transformer to me it is necessary to select for capacity?
As it is correct запитать 5 drivers
If it is possible, draw the scheme.
Yours faithfully Vasily!
Old Tue 18 May 2010, 16:04
Vasek,
here is the thread that talks about motor selection and calculation : Calculate the Voltage and VA size of the DC power supply for stepper motors/geckos
Old Wed 19 May 2010, 03:25
Because of the motors' inductance, the 80VDC maximum voltage of the stepper driver, you will be limited to 80VDC. A 50VAC transformer will develop 70VDC after rectification. A 55VAC transformer will develop 77VDC after rectification.
The motors will draw a maximum of 30.6A, if they all draw maximum current at the same time. You can probably use a 20A power supply, which is about 66% of 30.6A.
20A X 50VAC = 1,000VA
80,000 X 20A / 50V = 32,000 uF capacitors.
If I were building that power supply, I would use:
1 each 50VAC 1000VA transformer
5 each 6,800uF 160V capacitors (wired parallel)
1 each 400V 50A bridge rectifier
AnTek makes the PS-15N70 that is rated 21-Amps for $210. They also have the PS-10N70 that is rated 14-Amps for $150.
Why not use an adjustable, regulated power supply? Bob Cole 702. Power Supplies 19 Thu 25 August 2011 09:33
Wiring the PK296A2A-SG7.2 motors & power supply voltage selection Richards Motors & their mountings 97 Fri 29 July 2011 10:46
PMDX-122 power supply paul60 702. Power Supplies 1 Thu 10 September 2009 12:51
