Old Sun 07 March 2010, 13:47
Kitchen Fronts, Door Carving and Bus Parts #64 - Novi Sad, Serbia
My name is Danilo Macanovic from Novi Sad, Serbia.
Last year I have built a small cnc (50x70cm) with linear bearings, ballscrews and learned a lot, made my own drivers for unipolar steppers (Mardus Kreutz) and they worked flawless (it helps to have an expert Mardus in the neighborhood) .
From start I wanted a bigger more massive machine but did not have the funds for it at the time. Now with help of some friends the build may be successful. I printed the plans and read most of the forum so I did my homework.
I decided for the Geckos this time because I really want to see them in action
I have available rack module 1 and pinion with 20 and 30 teeth. Steel for the frame is relatively cheap here so it wont be problem. Also there is a laser cutting service near me so that too wont be a big problem...
As everything looks in a month or two there will be one mechmate more from this part of Europe
p.s. I plan on using mechmate for cutting mdf boards and all sorts of other wood, forex, plexiglass etc.
And not to forget, I am basically an electronics engineer but in love with cnc machines.
I have tons of questions so be prepared
Old Sun 07 March 2010, 17:10
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Danilo: Welcome to the project. Sounds like you are ready for a fast build. We are looking forward to the pictures. Joe
Old Sun 07 March 2010, 20:23
Welcome !!!
Old Sun 07 March 2010, 23:01
Johannescnc
Just call me: John
Hannover, DE
Germany
Willkommen!
Old Tue 09 March 2010, 15:42
Welcome Danilo!
Old Wed 10 March 2010, 20:15
digger
Just call me: Milosh #113
Toronto
Dobrodosao Danilo.
Old Fri 19 March 2010, 15:58
a little delay
MM has to wait a little becouse my colegues and me are building a bot for EUROBOT 2010 named Lily2, previous model Lily won in our national competion and made it till the quarter finals in Heilderberg Germany.
We made this one out of polypropilene and cut the parts on cnc.
Notice the beard! no time to shave when you start building a mechmate
Old Sat 05 June 2010, 12:22
Progress FINALLY!
After a very slow recovery here is the update!
I got my racks and 30 tooth pinions
Here are the laser cut and bent parts from my friend Milan!
I still have not cut the steel but had to paint it becouse of constant rain last 2 weeks.
I made a BOB with all the features I need for a MM, here is the PCB being made on my smaller cnc
and some foam letters for my friend which is helping me during the build
Old Mon 07 June 2010, 21:21
Codered741
Just call me: Cody
Lancaster (Pennsylvania)
Spider.
Is it just me, or is the spider way small. Seems like a Big gap between the spider and the side plate.
Also missed the bend for the gas strut mount.
You are movin quick! Good luck!
-Cody
Old Mon 07 June 2010, 23:01
They are all like that I think. Some washers as spacers on both sides, then it fits perfectly.
Old Mon 07 June 2010, 23:59
Cody, his y-car is not welded up yet....the parts are just loosely placed.
Old Tue 08 June 2010, 00:16
Codered741
Just call me: Cody
Of course...
Duh... I should have caught that... Never mind!
-Cody
Old Tue 08 June 2010, 05:15
Cody,
Summer vacation already catching up with you? ! LOL
Old Tue 08 June 2010, 05:47
Yes I placed it only too have a feel how it looks.
I was missing 100x50mm tube, got it today, so now I just need to take it all to friends machine shop
Milan's and mine motors 86HS9802 and a spindle from Deitech arrived too, will be getting them in next couple of days.
Will post some pictures as work continues!
Old Tue 08 June 2010, 23:42
Codered741
Just call me: Cody
Geez i hope not. I posted that from my phone in the airport, the dangers of surfing on a small screen. P
My bad! I'll look closer next time.
-Cody
Old Sat 12 June 2010, 10:11
Well these 3 days were busy!
Done the cutting and drilling all the rails and tubes
cutting is so easy with this
and this is me learning to work on this old mill, one day practice and all those levers make sense now!
Next week, rail grinding and welding!
Old Fri 18 June 2010, 09:37
Done the rails cutting today!
tommorow we'll do angles on them
Old Fri 25 June 2010, 09:55
And transformation of the mill
now its rail sharpener!
got my spindle (2.2kW) and motors 9802 from Deitech, great service thank you !
and bought gears and belts for reduction, really cheap from greece company Koumakis representative here in Serbia, set of 4 was 32 eur.
Old Sat 26 June 2010, 04:37
Man this is great!!! You have to love how the MechMate teaches us stuff as we go. Pushing us to learn the "trades". Machining,Welding,Electrical and Electronic ... CNC .... CAD ...CAM .... I can go on and on !!!!
Great to see all those old machines making a MechMate!!!!
Old Sun 01 August 2010, 15:01
Its just some colors I like
Finished painting now to fit the motors and get the cable chain
Old Sun 08 August 2010, 15:29
Wired the spindle and prepared the spider wheels, they are bit larger and I made 20 of them on cnc lathe so used 6 instead of 4.
I assembled the belt reductions that I made earlyer and they worked out pretty nice!
Pump for my 2.2kW spindle is Atman 105, its a bit larger than Milan's Atman 104 which is working fine for him but I got this one at a good price so went with larger.
Old Wed 25 August 2010, 16:41
Well I am near the finish line.
Mounted control buttons, and did some 3D tests. Other 2 pictures are from making of my own drivers Mardus-Kreutz unipolar. They work well but will be changed sometime in the future if i have to.
Old Wed 25 August 2010, 18:19
Nice work on the drivers!
Old Wed 25 August 2010, 20:12
Well done Danilo!
Old Wed 25 August 2010, 21:12
Congrats !!!
Old Thu 26 August 2010, 06:30
well done! Very fast build and good job on the electronics!
Old Thu 09 September 2010, 12:25
I posted my first job in showroom. I made the MechMate sticker but had no time to stick it to machine, first thing tommorow i will put some pictures of it completed.
here is the link to showroom:
http://www.mechmate.com/forums/showthread.php?t=3026
Old Fri 10 September 2010, 00:44
This MM needs a Serial Number!!!!!!
Old Fri 10 September 2010, 02:02
Wait I need stickers first
Old Fri 10 September 2010, 02:18
Minor problem. You have them.
Door panels lonestaral The Show Room 6 Fri 18 October 2013 19:35
New Serial Numbers #102 and #103 - Kikinda & Novi Sad, Serbia marcobc MechMates already cutting 28 Thu 06 September 2012 12:35
Introducing myself and starting planning - Novi Sad, Serbia mirkoni Introduce yourself and start planning 4 Sun 13 March 2011 08:26
Hi everybody - Indjija, Serbia therion_339 Introduce yourself and start planning 3 Sun 21 June 2009 04:05
Door decorations grandpi The Show Room 0 Wed 16 April 2008 13:06
