Old Sun 24 April 2011, 14:13
danhamm
Just call me: Dan
Williams Lake B.C. Canada
Yes there 6 I think 5mm tapped holes...but its into aluminum, seems ok though..I am remodeling my bot I picked up last winter..
Sorry for the quality...Iphone..pics
Old Sun 24 April 2011, 18:05
gmcclure
Just call me: Graeme
Geelong
Sorry Kobus,
I made the quick connection plate manually on a mill using DRO setpoints. The spindle does have 6 pre tapped hole in its body
regards
Graeme
Old Mon 25 April 2011, 02:25
Thanks. Can you give me the centre to centre dimentions so long. Then I can start with my plate.
Old Mon 25 April 2011, 04:29
Kobus, SEV.pdf is the file supplied by HSD, but the 36 mm between centers has been 30mm on one of our spindles.
Old Mon 25 April 2011, 07:06
Thank's Gerald.
Graeme and Dan, did you also pick up this problem ?
Maybe it will be safe to wait and measure it ON the actual spindle.
Old Mon 25 April 2011, 10:56
danhamm
Just call me: Dan
As I recall it was 30mm horizontal and 45 mm vertical total 90mm vertical.
I am talking about the air cooled 3kw huanyang spindle pretapped mounting holes on the back of body..
Old Mon 25 April 2011, 12:46
Here is our spindle with the 30mm spacing:
Old Mon 25 April 2011, 12:50
Kobus, sorry to confuse you, that first drawing with 36mm was a 4.5kW big one. Safest is to wait.
Also watch that the screws don't bottom in the tapped holes - they are very close to the coils inside. Don't make them too short either, otherwise you will strip the alu.
revved_up
Just call me: Craig
Hartland, MI
I have found that the ebay seller list the same spindle multiple times with different pricing so best to scroll thru all his listings
Old Mon 25 April 2011, 13:04
Different price, but then also different shipping cost...in the end the same price...
Old Mon 25 April 2011, 23:19
I run my present 2.2kW spindle in the region of 8~10A most of the time @16000~20000rpm depending on the cutter sharpness...
Been dreaming about uprating the spindle when money is available...
BUT 3kW or 4kW spindle... Just can not make up my mind...
Choice of support board materials SteveE 10. Base Table 14 Mon 16 January 2012 17:18
Fixing the spoilboard to the support board bradyaero 10. Base Table 20 Mon 06 September 2010 08:55
Hi Graeme from Geelong, Australia gmcclure Introduce yourself and start planning 5 Fri 22 January 2010 02:16
Support / Spoil board sizing domino11 10. Base Table 5 Mon 05 May 2008 07:09
Why the gap between the support/spoil board and beams? dmoore 10. Base Table 0 Wed 30 April 2008 11:51
