Old Sat 15 August 2009, 21:10
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Rail grinding process question
I have 2-1/2 by 2" angle iron stock. When cutting it down to the 1.1" required for the finished rail what is the correct process? Should I cut it first horizontally before cutting the angles on it? Or should I just grind the angles until I reach the final height? If I cut it first horizontally, to what height before starting to grind the angles? Or should I just go right to 1.1"? (I have seen all the photos and videos of folks cutting the angles horizontally first but haven't seen anything about the intermediate height, if any.) Thanks
Old Sat 15 August 2009, 23:03
bfauska
Just call me: Brian #30
Seattle, WA
The first cut should be to 1.1" and then after you grind the angles you should have a small flat on top that is actually left over from your original cut. If you have the laser cut parts with the grinder skate there is a way to use it to make the horizontal cut, but I had access to a steel cutting circular saw and did that instead. I actually think the finished cut is cleaner with the grinder.
Old Sun 16 August 2009, 10:19
jehayes
Thanks. I will use the grinder and skate system.
Messed up while cutting-grinding a rail kanankeban Rails & Rollers 3 Thu 29 January 2009 20:13
rail grinding - does the wheel need adjustment as it wears? DenisCasserly Rails & Rollers 3 Mon 12 January 2009 21:19
question on y-rail stops ekdenton Rails & Rollers 9 Fri 18 April 2008 06:14
Stymied on rail grinding - until the Pferd disks were found skypoke Rails & Rollers 3 Sun 09 March 2008 11:46
Grinding V-profile on rail edges Gerald_D Archives 65 Fri 24 November 2006 10:07
