Go Back   MechMate CNC Router Forum > Computing, Software & Programming > CAM
Old Sun 13 December 2009, 08:51
foinikas
Just call me: Sakis
Trikala
Greece
Free software for image edit and stl formats.
On of the best programs to open and edit .stl files is Meshlab ofc it is a open source program so no license required.
The best about meshlab is that can run in old pc's with an averange graphic card and can give you up of 60frames (i have old pc with athlon barton 2.5gh and an ati 9600pro 128mb and 1giga ram) you can check it here http://meshlab.sourceforge.net/ .
The best open source program for photo editing is GIMP it provides the same ...or better quallity as Photoshop and have varius plugins for free it can be found here
http://www.gimp.org/downloads/ . A main problem is the complex Gui that can be change using Gimpshop that can be found here http://plasticbugs.com/?page_id=294 .also a collection of free plugins for Gimp can be found here http://registry.gimp.org/ .
Ofc i can't pass the Freecad one of the best opensource cad programs for windows you can find it here http://sourceforge.net/apps/mediawik...itle=Main_Page also another simple program for editing cad files that worth to be metnion here is Qcad but not totally free it can be found here http://www.qcad.org/
Old Sat 19 December 2009, 01:41
foinikas
Just call me: Sakis
Trikala
Greece
Main page
http://inkscape.org/
Dowload link for windows v.0.47
http://sourceforge.net/projects/inks...3.exe/download
images created with inkscape
http://commons.wikimedia.org/wiki/Ca..._with_Inkscape
An Open Source vector graphics editor, with capabilities similar to Illustrator, CorelDraw, or Xara X, using the W3C standard Scalable Vector Graphics (SVG) file format.
I will keep this thread updated ONLY with Open Source / GPL software.
I know that maybe all of you know most of this software but is good all of this to be under the same thread.
Old Sun 27 December 2009, 14:30
ger21
Just call me: Ger
Detroit, MI
Here's a free v12 .dxf exporter that works better than the built in Inkscape exporter.
http://mydxf.blogspot.com/2008/11/inkscape-r12-dxf.html
Old Mon 28 December 2009, 10:55
foinikas
Just call me: Sakis
Trikala
Greece
Inskape r12
As it is described in the above blog :
Inkscape is a great open program, that allows you to create & edit many types of vector files. What I found was that Inkscape had an issue with saving AutoCAD DXF files that will open in many, If not all cad programs. Being the type of person that can't leave well enough alone, & knowing that dxf files are really just simple text files that can be edited in any text editor, I set out to search the net with my trusty sidekick Google.
Now my goal is to get Inkscape to save a dxf file as a version 12 format. After looking thru the modified Inkscape files over at bobcookdev.com , I had a good idea what needed to be done to get Inkscape exporting in R12 dxf format.
With the help of cnczone members, two sample files were tested to see If either dxf file had any issues, as of this blog post, no problems.
I have only tested this with Inkscape 0.46 on Windows XP.
Installation:
Download the zip file Inkscape_R12_Dxf.zip (4.51kb). It contains:
simpletransform.py (this replaces an existing file)
mydxf_templates.py
mydxf_outlines.inx
mydxf_outlines.py
Extract the four files and install them into ( C:\Program Files\Inkscape\share\extensions ) this should be the default path that Inkscape saves to when first installing Inkscape, then restart Inkscape to activate.
When you are ready to save a file in Inkscape, the new extension is DXF R12 (*.DXF) , listed in the "Save As..." window
Consider to give it a try,thanks for the info Ger.
Old Tue 29 December 2009, 08:25
normand blais
Just call me: Normand
montreal
Hi I could not find the cam part?
Old Tue 29 December 2009, 16:20
foinikas
Just call me: Sakis
Trikala
Greece
The download Link for the inkscape is located here :
http://bobcookdev.com/inkscape/better_dxf_output.zip check this also http://tim.cexx.org/?p=590
http://sites.google.com/site/mydxfbl...pe_R12_Dxf.zip
direct link for download.
"Better Better DXF Output for Inkscape
Just unzip into your \Inkskape\share\extensions directory. Note that the updated ’simpletransforms.py’ replaces an existing file.
Note: There is still an outstanding issue with Grouped objects in Inkscape being exported with incorrect size. As I understand it (assuming the document structure sent to export scripts is substantially an SVG file), transforms are applied at the Group level, which is sort of a container that has the actual drawing objects (and possibly further nested groups) as its children. Guessing that to handle this correctly, rather than looking for transforms at the node itself, it must also maintain a stack of transforms that have been applied at the node’s parent level, and parent’s parent, etc. For now, it is an easy workaround to ungroup everything before export. Maybe someone with freetime can update this and release it as ‘Better Better Better DXF Output’ :-) (b3dxf?)"
Old Mon 04 January 2010, 07:01
foinikas
Just call me: Sakis
Trikala
Greece
Raster to Vector
I have found a very interesting article in the wikipedia about raster to vector with the name :
"Comparison of raster to vector conversion software"
here is the link http://en.wikipedia.org/wiki/Compari...rsion_software
and here is a part of the page with the software under GPL and Free for personal use.
This table gives basic general information about the different vector graphics editors:
Name
Creator
Released
Latest version
List price (USD)
License
AutoTrace
Martin Weber
1998
0.31.1
free
GPL
Potrace
Peter Selinger
2001
1.8
free
GPL
Ras2Vec
Davide Libenzi
1989
1.2
free
GPL
Image2XAML
Roman Kalachik
2008
0.7
free
GPL
Raster to Vector
RaveGrid
2006
2.5
free for personal use
(commercial licenses available)
Proprietary
WinTopo Freeware
SoftSoft
1998
1.661
free
Proprietary
RasVector
Daniel Lu
2007
1.1.5 b6
free
GPL
Xara Xtreme
Xara Group Ltd.
2006
2.0f
79$ for Windows, free for Linux
GPL
Name
Creator
Released
Latest version
List price (USD)
License
Old Thu 04 February 2010, 09:35
foinikas
Just call me: Sakis
Trikala
Greece
7zip
7zip is one of the best compration programs ,ofc it isnt a Cam/cad program but it can be used to solve Storage problems since offer the best compration.
Here is the website link: http://www.7-zip.org/
Faq: http://www.7-zip.org/faq.html
Wikipedia : http://en.wikipedia.org/wiki/7-Zip
Just to say hi.. and point folks in the direction of some FREE software. yohudi Archives 8 Sat 27 August 2016 16:58
Converting file formats smreish Dxf Library 16 Tue 01 June 2010 06:14
Computersculpture.com for 3d scanners, CAD software, CAM software, and Desktop Mills awerby The Market Place 7 Mon 04 May 2009 08:23
Indexer software Art Archives 6 Tue 15 July 2008 08:43
What software do I need for 5-axis capability? joepardy Archives 7 Mon 05 November 2007 22:43
