Thread Tools |
#1
Clamping device for small jobs
I developed a need for a clamping method for doing small jobs that are repeated many times. This is the clamp thing that I came up with, it works very well. If you paint it you can use it to cut aluminium and steel with a lubricant or coolant. The MDF will not damage.
I sealed all the parts first with a water based sealer and then painted it with a hammer tone finish. There are some ugly marks on the thing because I could not wait for the paint to dry properly. I had to cut this 3D clock for my wife and then do the pocket at the back. Following are some pics of the parts. Note the inserts used - 8mm self threading insert and a 8mm "T" nut or furniture nut. |
#2
I like this a lot.
#3
Cool Idea! Thanks for sharing!
#4
Pleasure is mine. I forgot to mention the material is 30mm MDF. You can see the tool sizes from the G-code.
#5
Thanks Marius, that looks much nicer than my thrown together bits and pieces I have used in the past.
#6
Very nice looking slot table. Thanks for sharing
#7
Very useful. Thanks for the files.
Canīt wait to have MM up and running, I got so many Projects to do.... |
#8
Claus believe me once you have the machine the projects multiply.
#9
That's so nice! The slot table looks so perfect in every way that is why it is obviously very useful.
#10
MDF is magic stuff. I have made many tools using MDF.
#11
Nicely done.
#12
Hi is anyone having trouble D/L the above zip file
thanks |
#13
Just tried, it works. PM me I will send it to you if you dont come right.
#14
I just grabbed it. Works for me?
Thanks Marius for the file! When I first saw your post, I thought you had based your wooden table on the metal one...then realized that the metal one, is the wood painted Thanks again Mark |
#15
You're welcome man. I painted the unit with a hammer tone finish to seal it all round as I was cutting aluminium that needed some coolant. That was the only paint I had at hand.
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
A very simple sanding device | gixi | Miscellaneous / General / Whatever / Catchall | 2 | Mon 29 June 2009 08:14 |
Cam Type Clamping Fixture | Rad Racer | General - MM Operating | 0 | Sun 05 April 2009 22:55 |
Small World or Not | Kobus_Joubert | Archives | 0 | Fri 25 January 2008 12:37 |
V-Rail profiling device - an alternative skate design | Atifeh | Rails & Rollers | 9 | Fri 25 January 2008 10:12 |
Small problems | Admin | Test Area for this forum | 14 | Sun 03 June 2007 00:41 |
