Old Fri 19 January 2007, 21:11
Z-slide Limit Stops
The drawings don't explain this:
A & B are 5mm [5/16"] screws tapped into the back of the tube. They impact (seldom) against the bent tab C of the spider plate.
Position the screw heads so that:
a. The pinion does not run off the end of the rack.
b. The slide does not run out of the V-rollers
c. The gas spring does not reach its internal limits.
These screws were not defined in the drawings because of the unknown factors of which gas springs you are getting.
Old Fri 23 January 2015, 00:37
Craftycreationsnv
Just call me: Russ
Silver springs
how many lbs does the gas spring need to be
Old Fri 23 January 2015, 06:25
digit
Just call me: Dominic
Quebec
To null weight of your spindle
Old Fri 23 January 2015, 13:45
Fox
Just call me: Fox
Amsterdam
correction; to balance the weight of your entire Z-slide including your spindle.
