Old Mon 12 October 2009, 14:25
Travish
Just call me: Travis #75
Wa
Router Speed/RPM Control
Has anyone had any success or where to start on controlling the routers spindle speed via mach 3 control? What are most people doing? Are people just adjusting the speed manually on the fly or with a simple inline Potentiometer made for routers? It would be handy be able to use this funtion.
Travis
Old Sat 17 October 2009, 05:46
read travis read
start here
http://www.mechmate.com/forums/showthread.php?t=290
Old Sat 17 October 2009, 07:23
Irfan, I think that thread only addresses ON/OFF and not variable speed control?
Old Sat 17 October 2009, 07:55
Yes G' its a start - to start with -
then travis could also look at this
Old Sat 17 October 2009, 21:14
Travish
Wa
Interesting find Irfan!
Thanks for the link! Looks like it would will work up to 2.5hp or 1800 watt routers. I'll read up on it and see how promising it looks.
Old Sun 18 October 2009, 08:49
Travis if budget is not so very a constraint I would strongly suggest a 1.5KW chinese spindle with a 1.5KW Delta VFD, both put together would cost approx 600USD, and another 100 for water cooling maybe!
my best to you.
RGDS
Irfan
Solid State Relay (SSR) for switching Router under control of Mach3 Gerald_D 70. Control Systems 77 Tue 07 January 2020 18:43
Max. speed of the MechMate - moving, cutting, jogging . . . . sprayhead General - MM Build 31 Fri 19 February 2010 05:28
Speed Test isladelobos General - MM Operating 1 Tue 13 October 2009 04:07
What type of cutter to use and what feeding speed to cut aluminium hennie Cutting various materials - bit selection, feeds, speeds 1 Fri 24 July 2009 09:24
Router speed control coogrrr 50. Toolheads 18 Sat 23 February 2008 03:05
