Old Tue 17 November 2009, 16:36
Atifeh
Just call me: Nader
Tehran
Iran
Thanks all for the ideas. For now I will leave it as it is, as Gerald suggested, but in the future I will use Allan's Idea which is the most simple and yet does not confine accessibility.
Old Tue 17 November 2009, 16:45
Atifeh
Just call me: Nader
Tehran
Iran
Greetings to all,
These past weeks, besides a hectic period of work, mostly I managed some other activities.
Bought the whole lot of electrical parts and cables for the next stage.
Bought the computer but have not set it up yet.
Designed a whole new set of power board, 12/5 V board, pwm to 0-10 V and a more compact breakout board (since I have to use two boards). Had them printed on film and made the bare boards.
Attended a one day course for programming the DELTA VFD-E, which I learned how to interface it with external signals. These VFD’s have a lot of potential and I think it is worth learning the plc section of it.
I will be revising the electric schematic which will be posted after completion. Now the VFD will work in two modes, 1- which receives the start and pwm from MACH. 2- a switchover which overrides MACH and gets the RUN and rpm manually, through its detachable mini panel.
I decided on this switch in order to execute the warm up sequence as devised by Mr. Richards without entering MACH. I would not be using the reverse turning, as my spindle is an ER20 collet. Reversing will probably loosen the nut and be quite dangerous. Please tell me of any possible uses for reversing the spindle. The only use I could imagine is for tapping.
Besides, these were the progress made on the machine:
Mounting the racks:
As you have noticed, I use 35mm, M6 screws to hold the rack at a distance from its final position. This provides enough room to strip the double sided tape. For the X axis a middle support is used as well. Then the screws are turned and the rack is elevated to about 2mm below its final position. This facilitates the positioning of the rack and provides a means to once again check the linearity of the rack against the rail. After binding the rails, the screws will be replaced with M6x25mm.
Z plate:
These were the original plates for mounting the spindle.
I revised them to incorporate several holes for: attaching a Z echain, bracket for home and limit switch, a moveable dust collector attachment, additional holes for relocating the spindle plate:
Arrangement for the tension springs.
Old Tue 17 November 2009, 18:11
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Nader: Very nice! Thanks for the great and instructive pictures.
Old Sat 21 November 2009, 14:40
Atifeh
Just call me: Nader
Tehran
Iran
Thanks Joe,
Hope they are helpful.
Besides the VFD and the drivers which I bought, I made two buffered breakout boards and a 12/5 V regulated power supply.
I wonder if I could use the 12V for the PWM to 0-10V board for the VFD, as the 12V and the 5V have common grounds. Any comments?
I decided to install an echain for the Z axis which might prove useful in the future; an air hose for a high speed turbine spindle, a water colled spindle or … The size is 25x30mm.
This is the configuration that I use in my gearboxes. A M12 bolt through a bronze bushing, 13mm high. The gearbox stands clear from the support arm by about 1mm which could be less if i grind the bushing.
I tried the standard MechMate 35 turns, 2mm wire, 16mm OD, with elongated length of 128mm, which happened to be unsuitable. While cranking the Z plate down manually, at a point the pinion slipped off the rack. I made a spring with 16 turn, which is very hard to expand and the slipping was eliminated. Now I have to optimize the length of the spring. I suspect this problem is due to slope of the spring and the horizontal vector of the force.
Here is the detail of the spring assembly:
Old Sun 22 November 2009, 07:56
liaoh75
Just call me: David
Taibao
Taiwan
Nader, very interesting build. Please keep the pics coming!
Old Mon 23 November 2009, 13:12
Atifeh
Just call me: Nader
Tehran
Iran
I changed the Z motor spring to 30 turns of 2.2 mm wire, 16 mmOD. Still slipping. Reduced the number of turns to 23 and it works fine.
I guess the below picture shows the fault. The point of effect of the spring is very much near the pinion axis, not providing enough leverage. The spring should be attached farther up.
The components and arrangement for the Z axis home and limit switch.
Details of Y axis echain:
Old Mon 23 November 2009, 22:12
Nader, that y-car design (bolted rectangle) was used by ShopBot and it was not a success. The major cure for the weak rectangle was to add a second y-motor. Another cure was to add a plate over the rectangle - link
Old Tue 24 November 2009, 15:40
Atifeh
Just call me: Nader
Tehran
Iran
Thanks for the hint and the link. I studied it but could not comprehend the problem. What was the problem with the ShopBot? What stress condition made it faulty?
Thanks.
Old Tue 24 November 2009, 15:59
Nader,
Your machine is looking really good.
Old Tue 24 November 2009, 21:54
A 5-minute sketch:
Old Thu 26 November 2009, 17:32
Atifeh
Just call me: Nader
Tehran
Iran
Thanks Nils,
Thanks Gerald,
I got the problem. Do you think that welding the rectangle structure members together will help eliminate this problem? I have to say that the square tubes were quite fit to the angles and bolting them was actually a bit hard.
Old Thu 26 November 2009, 19:58
Nader, I would rather not discuss that further. I am trying very hard to concentrate on the MechMate design only.
Old Fri 04 December 2009, 21:08
wiwatto
Just call me: wiwatto
Bangkok
Dear Gerald
Take it easy SIR, Don't worry about your MechMate design, even you got more questions or 10,000 photographs. Since June 2007, I know what is the Real MechMate Design. And i hopefully everyone also.
Thank you very much for your hard work on the MechMate.
Nobody, will change my mind " Gerald D is my hero"
Old Fri 04 December 2009, 22:55
I not worried about the MM design (and it is NOT perfect), I am only worried about what will happen to my free time and this forum if I start discussing other designs.
Old Sat 05 December 2009, 15:15
Atifeh
Just call me: Nader
Tehran
Iran
I personally agree with Gerald. If I were in his place my answer would be the same. It is not fair to introduce various designs and ask him to comment. Gerald was very considerate to note a fault in my machine. I myself, have to improve it with my mindset on my own design (which somehow I did).
Old Sat 05 December 2009, 15:18
Atifeh
Just call me: Nader
Tehran
Iran
Details of X axis echain: after the echain a sheet metal duct is installed. A perforated plate has been devised to carry one end of the flexible cable hose.
Spindle and its mounting plate installed.
Old Sat 05 December 2009, 15:33
Atifeh
Just call me: Nader
Tehran
Iran
Starting the electrical
The cables I use. From top to bottom:
Common ground signals cable (except for the motors), i.e. Estop signal (pin10), Pause, Resume, Zset, Home X1,X2,Y,Z,B and GND.
Spindle cable.
Motors cables.
Microswitches routing and Limit Switches/Estop 12VAC cables.
I started with the cabling of the machine, soon to notice I have to clear up the matter of the control panel, regarding its entries and exits. So I left the cabling and will attend to that after completing the panel.
As you may have noticed, there are no free walls inside this workshop in order to hang the control panel. Also I might be moving this machine to another workshop. So some flexibility should be considered and I have to make a portable one.
Ordered a 500x700x220 mm control panel. Upon collecting it, I noticed he made a mistake and made it to 500x800x220 mm. He gave me a discount to the initial price for his error. All for the better! Now I can install the VFD inside the box.
These are the panel and the support structure.
Here are the sequences for its preparation.
The first step was to locate various components inside the box with minimum voltage interference, considering the routes for the cables, interfacing connectors and input/output devices, and also their location outside the panel walls and door. Also the path of the cooling air to the VFD, the drivers and the transformer should be considered. Metallic plates might be even necessary to channel the air flow to the desired path. I tried different layouts and this was chosen:
The next step was to mark the location of the ducts and other components, inside the box.
Next I measured different components dimensions and draw and printed them on paper. Glued them on each panel surface, center pinned and drilled them. Holes larger than 16 mm were cut by hole saw. Sizes: 19, 22, 25 and 43 mm are usually the most common for preparing a panel. For 120 mm fan a 114 mm hole saw should be used. All cuts were done by hand drill.
All holes were deburred both from inside and outside, as this is really crucial. This is one side completed:
Two rectangular openings should be made. 1- for VFD’s mini keyboard. 2- for the parallel ports.
Here is my method for making rectangular opening on the control panel.
Cutting is done with the remainder of the cutting disks used for cutting the rails. These depleted disks have reduced diameter and work better in short distances. A diagonal cut helps to separate each tab easily. The rest will be finished by filing.
This is the double LPT port interface:
Here are the views of the completed bare box.
The transformer is quite heavy and will be backed by this U channel. The angle will support the other end of the flexible cable hose. Therefore, for moving the machine, the only tasks to be done are to disconnect the connectors, the earth wire and this angle iron. Then the control panel can be moved independently.
The auto air filter and its assembly components. Two off will be installed. One just above the VFD and the other one to provide air for the drivers.
Old Mon 07 December 2009, 12:19
Atifeh
Just call me: Nader
Tehran
Iran
Wiring diagram update
The following changes have been reflected in the new diagram:
Some errative colour coded wires are corrected.
The preliminary wiring of the VFD and the 0-10V board are added.
Another Estop switch added on the panel.
There amy be other revisions.
For DELTA type-E VFD the following programs are to be done:
MI1 -- 02.01 = 2 (external terminal, keypad start/stop disabled)
MI3 -- 04.05 = 8 (operation command selector = external terminal)
MI4 -- 04.06 = 19 (operation command selector = keypad)
MI5 -- 04.07 = 22 (source of second frequency command)
DCM -- 02.09 = 4 (source of 2nd frequency command = digital keypad potentiometer)
Also.
AVI -- 02.00 = 1 (source of 1st master frequency)
The attached file is a zipped .dxf file
electrical UR8a4.rar
Old Mon 07 December 2009, 12:29
Atifeh
Just call me: Nader
Tehran
Iran
Wiring of the control panel
Here will be the stages of wiring the control panel as I progress.
Prior to starting, the box was vacuum cleaned and cleaned with a damp cloth. No traces of drilling chips.
Placing and securing the cable ducts inside the panel:
These are the consumables normally used for wiring.
The wiring operation will be divided into 4 stages:
The 220VAC stage, the VFD stage, the drivers stage and the breakout and interface stage.
The 220 VAC wiring stage:
The relay and terminal blocks mounted on the DIN rail and tag numbered. Please note the spacer under the rail for ease of wiring (idea from Gerald).
All other components related to this stage are mounted in their respective places.
This is the space I made myself to start with the wiring.
The 220VAC stage completed. All wires tagged according to the drawing:
Mounting the VFD and connecting the feed wires. Mounting the transformers:
Fastening the transformer from behind.
Mounting the 39VDC module:
Old Tue 08 December 2009, 10:12
thats actually good organized work - I am so ashamed
Old Tue 15 December 2009, 12:54
Zanchet
Just call me: Luci
Florianópolis
Brazil
Nader
You´re the MAN!
Old Tue 15 December 2009, 13:44
Atifeh
Just call me: Nader
Tehran
Iran
Connecting the drivers
Connector side of motors wiring:
Driver side with separate grounds for motors wiring:
Arrangement of the motor/driver wires:
Preparation of wires between the driver and the DC power supply.
Placing the drivers and its wiring. Duct covers removed to show the routes better.
Details of power supply connection. To avoid clutter around the driver, the second set of ground wires are connected on the power supply side, rather than the driver side.
Spindle UVW connection:
Connection route of the VFD switchover switch and the mini keypad to the VFD. Another Estop is also routed through this cable duct.
Mounting the 5/12 VDC power suppy:
The PWM to 0-10V board is still under development, therefore I have to run the spindle in manual mode. Upon completion, I will start a separate thread for it.
Old Tue 15 December 2009, 13:51
Atifeh
Just call me: Nader
Tehran
Iran
Here are a set of carbide bits, newly bought. Although I was told that they are usually used by stone cutters but they work outstanding on MDF. On the other machine, a 6mm diameter tool cuts 6 mm depth per pass @1700 mm/min without any deflection in the tool. I have not tested them beyond this limits but I suppose they have the potential for more. Wall faces are smooth with acceptable tool marks.
These are 5,6 and 8 mm shanks.
These I have bought to test the 4th axis. 6mm shanks:
Old Tue 15 December 2009, 23:26
Nader, nice panel layout. Ideally those drivers should be mounted vertically so that the heat can dissipate off the fins of the heatsinks. as they are now you might get hot air pockets collecting under each heatsink. I know you are going to have fans on the case but I doubt much air will move through there. Of course it also depends on how much heat those drivers will generate - it might be of no concern - perhaps Mike Richards could weigh in here, he has far mor experience with these kind of layouts.
Never mind, I see above you have considered even putting in baffles if required - it would help if I read properly before commenting.
Old Wed 16 December 2009, 01:14
Nadar,
I second Alan's concern. The drivers might be just a bit too closely spaced to encourage air flow. I not an expert in this as well, it might not be a concern if the drivers never heat up.
Old Wed 16 December 2009, 13:12
Atifeh
Just call me: Nader
Tehran
Iran
Alan, Ken,
Thanks for your comments. You are both right. To tell you the truth, my first layout was that the drivers were arranged vertically, drawing air from above, but in order to have isolation of high voltage to control voltage, and also to have access to the microstep setting dip switches, I had to place them upside down. I just didn't like the idea to read the texts on the driver upside down!!
In the previous machine, the motors were wired unipolar. They actually worked with very little heat generated. The motors were 3 Amps. Now they will be 4.5 Amps and wired bipolar serial (except for the 4th axis which will be wired bipolar parallel) and I am not aware of their behaviour, but we'll see how it goes.
After finishing the panel (which you will see in the next post), I noticed that baffling might not be a feasible idea, but as you may have noticed there is a space between the VFD and the drivers, just above the 5/12 volts power supply. I could add a couple of 12V computer fans if the temperature builds up.
Old Wed 16 December 2009, 13:29
Atifeh
Just call me: Nader
Tehran
Iran
Finishing the control panel
This is a single connector that incorporates: Estop signal, Home (X1,Y,Z), Home X2, Home B, Pause, Resume, Zset and a common GND.
All the wires that will lead to the breakout boards:
Breakout boards are installed and wired.
Connectors between the parallel ports and the breakout boards are attached.
Den of snakes, i.e. the grounding hub. Two more wires will be passed. 1- the 6mm wire from the machine, 2- the wire that goes into the earth.
A thorough vacuum cleaning was in order to remove any residue of snapped wires. This is the panel almost finished.
Please ignore the yellow/green wire that goes from the transformer secondary to the ground. It was an aweful mistake and will be replaced by the negative line, just after the bridge to the grounding hub.
Air filters installed:
Pictures of the work. Nameplates will be attached later.
A 60 mm cable duct attached to the panel chassis (with double sided tape) which will carry the cables to the other side of the panel.
Nail varnish on M3 nuts and screw ends on the back of the panel to restrict their loosening.
Next step will be wiring the machine.
Old Wed 16 December 2009, 14:39
Nader, As clean as one can do…. you’re the guy
Very inspiring for many !
Thanks for sharing those. Amicalement, Robert
Old Wed 16 December 2009, 15:31
Claudiu
Just call me: Claus #43
Arad
Nader, that came out professional! Good Job.
Old Thu 17 December 2009, 14:45
Atifeh
Just call me: Nader
Tehran
Iran
Robert, Claus,
Thanks. These works are inspired by your and others works in this forum.
Now has AC SERVOs #111 – Georgetown, TX 711man MechMates already cutting 95 Tue 10 July 2018 12:24
New MechMate painted, with experimental control box - Atibaia, Brazil zetacnc MechMates already cutting 48 Tue 13 July 2010 00:37
